Post new topic Reply to topic  [ 440 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18
Author Message
 Post subject: Re: Raspbian/Ubuntu packages for dump1090-mutability availab
PostPosted: Sat Jan 23, 2016 7:09 am
Offline
FlightAware Staff
obj - FlightAware user avatar
It adds a little DC filter which helps remove the DC spike that some systems have. In my tests it didn't really improve things.
Top
 Profile
PostPosted: Sun Jan 24, 2016 8:42 pm
Offline
FlightAware Member
sjacket99 - FlightAware user avatar
I wanted to redo my sd card. So I did and I installed Dump1090 again like I did so many times before with no issue. But this time I am having issues. I installed Dump1090 with the following commands. But now when you run the last command and it ask if you want to start Dump1090 Auto, Then it ask for a port number. But you can't get past it.
So I re did my sd again and tried to install the dump1090 V1.14, but that kind of said the same thing. The commands for V1.15-dev worked for me the other day with no issue.
Code:
wget https://github.com/mutability/librtlsdr/releases/download/v0.5.4_git-1/librtlsdr0_0.5.4.git-1_armhf.deb
wget https://github.com/mutability/librtlsdr/releases/download/v0.5.4_git-1/librtlsdr-dev_0.5.4.git-1_armhf.deb
sudo dpkg -i librtlsdr0_0.5.4.git-1_armhf.deb
sudo dpkg -i librtlsdr-dev_0.5.4.git-1_armhf.deb
sudo apt-get install git-core
mkdir git
cd git
git clone https://github.com/mutability/dump1090.git
sudo apt-get install librtlsdr-dev libusb-1.0-0-dev pkg-config debhelper
cd dump1090
dpkg-buildpackage -b
(Get back into the git DIR first before running this command) sudo dpkg -i dump1090-mutability_1.15~dev_armhf.deb
Any help would be great. Thanks.
Top
 Profile
PostPosted: Sun Jan 24, 2016 8:52 pm
Offline
FlightAware Member
jprochazka - FlightAware user avatar
Code:
mkdir git
cd git
cd dump1090
Misread your post... Never mind what was posted before. I have not had any issue with "dpkg-buildpackage -b". however the following still holds true for me.
I have not been able to successfully install, well actually configure dump1090-mutability since the "Support multiple listening ports per listener type." commit earlier today. Here is a link to the latest issue I have ran into. https://github.com/mutability/dump1090/issues/92
Top
 Profile
PostPosted: Sun Jan 24, 2016 9:04 pm
Offline
FlightAware Member
It's weird because I just did the same commands that I posted Friday or Saturday and it worked with no issue.
Top
 Profile
PostPosted: Sun Jan 24, 2016 9:47 pm
Offline
FlightAware Staff
Yeah. HEAD packaging is broken currently. While it has been pretty stable lately, it is a development version. Use a version from a couple of days ago? Try 1a2926b31140e59e49795740c88642d4ff528ef6
Top
 Profile
PostPosted: Fri Jul 08, 2016 9:39 am
Offline
cmuncy - FlightAware user avatar
Is anyone running the latest code have their site accessible from the internet that I could look at?
Top
 Profile
PostPosted: Tue Jul 12, 2016 7:32 am
Offline
pgjp6910 - FlightAware user avatar
Hi, since a few days I can't see my dump1090-mutability site from the internet properly. I was wondering if it affected to other user sites or only to my. But after yesterday's update (via git) I can't see any plane, just empty map. What was happened?
Best regards,
pp
Top
 Profile
PostPosted: Tue Jul 12, 2016 9:40 am
Offline
FlightAware Member
jonhawkes2030 - FlightAware user avatar
Look at
post195613.html?hilit=openlayers#p195613
Also,
ads-b-flight-tracking-f21/what-is-the-maximum-range-i-can-get-t35912.html?hilit=google%20api&start=350
It is an issue with a new google API Policy.
It can be resolved on older setup. New Setups need to use one of the available maps.
Top
 Profile
PostPosted: Tue Jul 12, 2016 12:12 pm
Offline
jonhawkes2030 wrote:
Look at
Also,
Hi, thanks a lot for such quick response and hints, but seems, that I can't see planes even if I choose other map, such as OpenStreetMap.
Despite of this, I don't know how to use the Google Api Key, so it seems I stuck... My mom always told me "if something is working good enough, do not touch it", why I just didn't listen my mom ;)
EDIT: I added API Key, but still no planes. aghhh
EDIT2: I guess I found the reason of my problem. Some time ago I changed my files within html directory a bit. And today, I replaced whole files one by one from one of my very old backup. And two of them caused the issue, there was: scripts.js and planeObjects.js. And my current markers.js shows planes as "pins", but the old one correct it. Strange...
Best regards,
pp
Top
 Profile
PostPosted: Wed Feb 01, 2017 10:20 am
Offline
mostlychris - FlightAware user avatar
I apologize if this has been asked already. Is there a way to limit the number of history points that are displayed for aircraft? I have military training aircraft in my area and it makes a real mess on my web UI with all the tracks from those aircraft.
Top
 Profile
PostPosted: Wed Feb 01, 2017 1:53 pm
Offline
FlightAware Member
dump1090-fa allows you to specify an aircraft altitude range.
If the military aircraft are low, you could easily filter them out.
Top
 Profile
PostPosted: Wed Feb 01, 2017 4:24 pm
Offline
They fly from ground to high altitudes so that won't work. I'm interested in limiting the history for all aircraft.
Top
 Profile
PostPosted: Wed Feb 01, 2017 4:51 pm
Offline
FlightAware Staff
Not with the current dump1090 javascript, no. You could implement a maximum number of track points per aircraft without a ton of work. Implementing a global limit is harder.
Top
 Profile
PostPosted: Wed Feb 01, 2017 4:58 pm
Offline
Per aircraft is exactly what I'm looking for. If you can point me to the js file that this might work out of, I can take a look.
Top
 Profile
PostPosted: Wed Feb 01, 2017 6:29 pm
Offline
FlightAware Staff
Probably somewhere in here: https://github.com/flightaware/dump1090 ... ct.js#L190
Top
 Profile
Who is online
Users browsing this forum: dschre, ldefranco and 1 guest
Search for:
Jump to:
