Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Problem fetching data from dump1090
PostPosted: Sun Mar 19, 2017 2:25 pm
Offline
chrisrust - FlightAware user avatar
I am receiving the error message: Problem fetching data from dump1090. AJAX call failed (timeout: timeout). Maybe dump1090 is no longer running? The displayed map data will be out date.
I tried to fix the issue by reinstalling the PiAware software. I downloaded PiAware on Raspbian Linux 3.3.0 and used Etcher to install the image.
The Raspberry Pi 3 is connected via WiFi.
Any ideas on how to fix this?
Thanks..
Top
 Profile
 Post subject:
PostPosted: Sun Mar 19, 2017 6:40 pm
Offline
FlightAware Member
jvcdcarlos - FlightAware user avatar
that seems dump1090 is not running or problem mit dongle try this:
sudo etc/unit. d/dump1090. sh restart
if not works try unplug und pluging back the dongle
if still not works do : rtl_test and post the results
Sent from my SM-N910F using Tapatalk
Top
 Profile
 Post subject: Re: Problem fetching data from dump1090
PostPosted: Sun Mar 19, 2017 7:37 pm
Offline
I decided to try connecting an ethernet cable to see if the issue might be with WiFi and that has fixed the problem. I've been running the Pi 3 for over a year on WiFi so I'm not sure why its a problem now.
Top
 Profile
PostPosted: Mon Mar 20, 2017 10:55 am
Online
FlightAware Staff
obj - FlightAware user avatar
Generally ajax errors mean that either:
1) the IP assigned to your piaware has changed and you are still using the old IP and your browser has the static content cached; or
2) your piaware has entirely lost network connectivity and your browser has the static content cached;
3) dump1090 has halted because you have a hardware problem with your dongle.
If you are running a recent piaware sdcard image then you can connect a HDMI monitor and the console will show some network & dump1090 status information.
Top
 Profile
Who is online
Users browsing this forum: Google [Bot], obj and 1 guest
Search for:
Jump to:
