Due to overwhelming demand for the FlightAware Pro Stick, we’re having inventory problems at some retailers. We’re manufacturing thousands more and are working to improve availability around the world.
FlightAware Pro Stick USB ADS-B Empfänger
von FlightAware
Geben Sie die erste Bewertung für diesen Artikel ab
Derzeit nicht verfügbar.
Ob und wann dieser Artikel wieder vorrätig sein wird, ist unbekannt.
You beat me to it. We’re back in stock in Europe and will begin re-stocking distributors worldwide this Friday, hopefully back in stock everywhere around 4/15.
Hi i received today pro stick but now i have a problem, my old Antenne from normal dvbt stick is not compatible, someone can point me how can i convert it, some adapter?
thanks in advance
What is your setup like?
Do you have the FA Filter? You can connect it directly to the filter, just ensure that their is not too much strain on the connection.
If not, you will need some sort of adapter. You can get them from Amazon.com or ebay or even some electronic stores.
The Pro stick uses an SMA connector (be care not to confuse it with SMA-RP connectors. They have the same size threads, but the internal gender is opposite).
I need to know your setup. Is it s straight cable to the antenna or do you use a short pig-tail?
("normal dvbt stick " is quite varied. They can come with F, SMA and MCX connectors)
Most of the small antennas that I purchased have a combined SMA/MCX connector(like the adapter you have a link to above). You can pull off the MCX/SMA adapter to make it MCX.
The adapter you referenced should work for you.
Do you have a filter? If not, then you will need to reduce the gain for the pro-stick to about 45db to start. You may need to experiment with the levels to see what works best in your location.
