Post new topic Reply to topic  [ 15 posts ]
Author Message
 Post subject: Pro Stick and Pro Stick Plus
PostPosted: Wed Jul 12, 2017 2:52 pm
Offline
mwlong - FlightAware user avatar
I just received my brand new Pro Stick Plus. I removed the Pro Stick (Orange) and filter and replaced it with the Pro Stick Plus (Blue). I did this on a Raspberry Pi 3 B and I am running PiAware 3.5 on it. I of course removed power during the swap. Now nothing is working. No planes appear on the dump1090 map and according to FlighAware my MLAT is off. So, I put everything back the way it was and all is good again. I want to be able to use the Pro Stick Plus. What am I doing wrong?
Top
 Profile
 Post subject: Re: Pro Stick and Pro Stick Plus
PostPosted: Wed Jul 12, 2017 2:58 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
What you did should work fine. Check your power supply. Is the red power LED on the Pi 3 solidly on?
Top
 Profile
PostPosted: Wed Jul 12, 2017 3:08 pm
Offline
Yes it is a steady red. And there is an ongoing error on my My ADS-B page with the gear on it:
[2017-07-12 15:05 CDT] no ADS-B data program seen listening on port 30005 for 131 seconds, next check in 60s
[2017-07-12 15:06 CDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
Top
 Profile
PostPosted: Wed Jul 12, 2017 3:36 pm
Offline
FlightAware Staff
Ok, so it's not obviously bad power.
Those log entries mean dump1090 is not starting correctly for some reason. You can try a few commands from the command line to try to diagnose it further:
Code:
sudo systemctl status dump1090-fa -l
sudo journalctl -u dump1090-fa
lsusb
dmesg | grep usb
Top
 Profile
PostPosted: Wed Jul 12, 2017 3:55 pm
Offline
Results:
pi@piaware:~$ sudo systemctl status dump1090-fa -l
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2017-07-12 15:50:55 CDT; 4s ago
Process: 1121 ExecStart=/usr/bin/dump1090-fa $RECEIVER_OPTIONS $DECODER_OPTIONS $NET_OPTIONS $JSON_OPTIONS $PIAWARE_DUMP1090_LOCATION_OPTIONS --write-json /run/dump1090-fa --quiet (code=exited, status=1/FAILURE)
Main PID: 1121 (code=exited, status=1/FAILURE)
Jul 12 15:50:55 piaware systemd[1]: Unit dump1090-fa.service entered failed state.
pi@piaware:~$ sudo journalctl -u dump1090-fa
-- Logs begin at Wed 2017-07-12 15:17:01 CDT, end at Wed 2017-07-
Jul 12 15:17:09 piaware systemd[1]: Starting dump1090 ADS-B recei
Jul 12 15:17:09 piaware systemd[1]: Started dump1090 ADS-B receiv
Jul 12 15:17:09 piaware dump1090-fa[538]: Wed Jul 12 15:17:09 201
Jul 12 15:17:09 piaware dump1090-fa[538]: rtlsdr: no supported de
Jul 12 15:17:09 piaware systemd[1]: dump1090-fa.service: main pro
Jul 12 15:17:09 piaware systemd[1]: Unit dump1090-fa.service ente
Jul 12 15:48:50 piaware systemd[1]: Stopping dump1090 ADS-B recei
Jul 12 15:48:50 piaware systemd[1]: Starting dump1090 ADS-B recei
Jul 12 15:48:50 piaware systemd[1]: Started dump1090 ADS-B receiv
Jul 12 15:48:50 piaware dump1090-fa[832]: Wed Jul 12 15:48:50 201
Jul 12 15:48:50 piaware dump1090-fa[832]: rtlsdr: no supported de
Jul 12 15:48:50 piaware systemd[1]: dump1090-fa.service: main pro
Jul 12 15:48:50 piaware systemd[1]: Unit dump1090-fa.service ente
Jul 12 15:49:20 piaware systemd[1]: dump1090-fa.service holdoff t
Jul 12 15:49:20 piaware systemd[1]: Stopping dump1090 ADS-B recei
Jul 12 15:49:23 piaware systemd[1]: Starting dump1090 ADS-B recei
Jul 12 15:49:23 piaware systemd[1]: Started dump1090 ADS-B receiv
Jul 12 15:49:23 piaware dump1090-fa[897]: Wed Jul 12 15:49:23 201
Jul 12 15:49:23 piaware dump1090-fa[897]: rtlsdr: no supported de
Jul 12 15:49:23 piaware systemd[1]: dump1090-fa.service: main pro
Jul 12 15:49:23 piaware systemd[1]: Unit dump1090-fa.service ente
Jul 12 15:49:53 piaware systemd[1]: dump1090-fa.service holdoff t
lsusb
pi@piaware:~$ lsusb
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg | grep usb
[ 0.155610] usbcore: registered new interface driver usbfs
[ 0.155691] usbcore: registered new interface driver hub
[ 0.155780] usbcore: registered new device driver usb
[ 1.106891] usbcore: registered new interface driver smsc95xx
[ 1.535903] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.535937] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.535970] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.536215] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.536225] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.536233] usb usb1: Product: DWC OTG Controller
[ 1.536241] usb usb1: Manufacturer: Linux 4.9.35-v7+ dwc_otg_hcd
[ 1.536249] usb usb1: SerialNumber: 3f980000.usb
[ 1.538040] usbcore: registered new interface driver usb-storage
[ 1.545444] usbcore: registered new interface driver usbhid
[ 1.545448] usbhid: USB HID core driver
[ 1.954298] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.184507] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.184518] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.504299] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.634561] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.634575] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.728236] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a8:f9:4e
[ 2.824261] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[ 2.924275] usb 1-1.5: device descriptor read/64, error -32
[ 3.144274] usb 1-1.5: device descriptor read/64, error -32
[ 3.364324] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
[ 3.464260] usb 1-1.5: device descriptor read/64, error -32
[ 3.684262] usb 1-1.5: device descriptor read/64, error -32
[ 3.904237] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
[ 4.344232] usb 1-1.5: device not accepting address 6, error -32
[ 4.444234] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
[ 4.884234] usb 1-1.5: device not accepting address 7, error -32
[ 4.884472] usb 1-1-port5: unable to enumerate USB device
[ 17.898277] usbcore: registered new interface driver brcmfmac
pi@piaware:~$
Top
 Profile
PostPosted: Wed Jul 12, 2017 6:20 pm
Offline
FlightAware Staff
Ok, that is most likely either a bad USB connection (try a different USB port on the Pi?) or a faulty dongle.
It _might_ still be bad power, so you might want to try a different power supply if you have a spare, but usually marginal power would manifest in other ways.
Top
 Profile
PostPosted: Wed Jul 12, 2017 6:33 pm
Offline
Ok, I will move it to a different port in the morning and let you know. Meanwhile can you get me of off the Antenna in the attic issue. I don't need to do that one, lol. I just got another email for it...
Top
 Profile
PostPosted: Wed Jul 12, 2017 7:10 pm
Offline
FlightAware Staff
I guess you mean the forum emails? You can manage them in the user control panel here: ucp.php?i=main&mode=subscribed
Top
 Profile
PostPosted: Thu Jul 13, 2017 5:41 am
Offline
Actually, I am using the same port that the Orange Pro Stick works in, so it isn't the port on the Raspberry Pi or I would have issues with it, too. How do I get a replacement that does work?
Top
 Profile
PostPosted: Thu Jul 13, 2017 8:00 am
Offline
FlightAware Staff
If it is a mechanical issue this is not necessarily true, the connectors may be slightly different. Try a different port anyway?
Organize this with whereever you bought it through. There should be no problem returning a faulty item.
Top
 Profile
PostPosted: Thu Jul 13, 2017 8:26 am
Offline
Ok I moved it and as I expected, it isn't the port. The results are the same. Also, Amazon has a bad batch of these. Reading the reviews NSY 3 17 do not work. I really don't want a 3rd one from them! They are inexpensive so rather than messing with a return, I just bought another one. Both are from the same batch and neither work! I need a better solution from you.
Top
 Profile
PostPosted: Thu Jul 13, 2017 9:22 am
Offline
FlightAware Staff
If you don't return it as faulty then we can't tell
a) whether it is a fault with the dongle or something specific to your setup (we need the faulty prostick back to be able to test it);
b) whether there is any pattern to faults (generally we get very few faulty returns)
So the better solution is "return the faulty dongle", not "buy another one".
Top
 Profile
PostPosted: Thu Jul 13, 2017 10:26 am
Offline
Akubra - FlightAware user avatar
I have a 3/17 too and two DOAs is very unlikely. A -32 is not as clear as a -110 USB read error but is very likely to be power related. Do you have a USB cable between the dongle and the Raspberry PI (suspect #1)? Have you tried a different power supply - can be anything, even a 12W Apple power supply + micro USB cable or an high amp power bank (suspect #2)?
Last resort, but often a permanent solution: power off the Pi, disconnect everything and let it cool down for 5 minutes. After that: plug everything back in and start the Pi again.
Top
 Profile
PostPosted: Thu Jul 13, 2017 12:47 pm
Offline
Thanks, I'll give those ideas a try.
Top
 Profile
PostPosted: Thu Jul 13, 2017 1:16 pm
Offline
The 5 minute idea made no difference. I don't have a cable between the dongle and the Pi. I have no 2.5 A power supplies with a micro USB cable end on it. I can get a 2.5 A power supply with the correct connector on it but I don't like the idea of spending $23.00 to make a $16.00 device work.
Top
 Profile
Who is online
Users browsing this forum: 41south, matth20man, RenatoRibeiro, turracaine and 1 guest
Search for:
Jump to:
