PiAware reinstallation - dump1090 is NOT producing data
So, I got tired of the SD-card filling up all the time, got a new one and decided I might as well just reinstall PiAware.
I followed the Build a new PiAware receiver
And the Optional Steps for Advanced Setup
My ADS-B stats says:
http://bildr.no/image/WHp0ZWFK.jpeg
However, the FlightAware dump1090 web interface displays this in bottom left corner:
http://bildr.no/image/UzllWTRD.jpeg
Problem fetching data from dump1090.
AJAX call failed (error: Not Found). Maybe dump1090 is no longer running?
The displayed map data will be out of date.
And when checking status:
pi@piaware:~$ sudo piaware-status
PiAware master process (piaware) is running with pid 463.
PiAware ADS-B client (faup1090) is not running.
Local ADS-B receiver (dump1090) is not running.
no program appears to be listening for connections on port 30005.
got 'couldn't open socket: connection refused'
pi@piaware:~$ sudo /etc/init.d/fadump1090.sh restart
sudo: /etc/init.d/fadump1090.sh: command not found
I searched the forum last night without finding anything that seemed to explain and solve my issue.
Please advice, so I can get my feed up again.
dump1090 is not running.
Try “sudo systemctl status dump1090-fa” and “sudo journalctl -u dump1090-fa” to see what’s gone wrong.
pi@piaware:~ $ sudo journalctl -u dump1090-fa
– Logs begin at Tue 2016-09-27 14:00:54 UTC, end at Tue 2016-09-27 14:02:46 UTC. –
Sep 27 14:01:03 piaware systemd[1]: Starting dump1090 ADS-B receiver (FlightAware customization)…
Sep 27 14:01:03 piaware systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Sep 27 14:01:03 piaware dump1090-fa[443]: Tue Sep 27 14:01:03 2016 UTC dump1090-fa v3.1.0 starting up.
Sep 27 14:01:03 piaware dump1090-fa[443]: Using sample converter: UC8, integer/table path
Sep 27 14:01:03 piaware dump1090-fa[443]: No supported devices found.
It turns out I added a faulty USB extension cord while setting up for reinstall…
Thanks!
