I have the most recent version of PiAware installed and for the 9 days, FlightAware has been reporting that the receiver has not checked in. I can use view1090 to see that it is pulling positions. If i run sudo piaware-config -status, nothing is reported. Just moves to the next command prompt. I have manually run the upgrade lines with the same results and restarted just the piaware app and also rebooted the device. Same results. Any suggestions?
If you want to, can you try to see if the packages are all there? Try doing the following (this will install a package called mlocate, update the files database and then we’ll search to see if everything is there…)
