Had a small issue with my PI running piaware, so I decided to start from scratch.
Downloaded the latest version “piaware-jessie-sd-card-2.1-5” after installation when giving the command “startx” the response is ‘command not found’.
Is there a new command to start the GUI or what can be wrong?
Adding a GUI to Jessie Lite should not be that hard.
Note: I almost never use a GUI and cannot guarantee the outcome however in theory this should work.
I am pretty sure the default GUI in Raspbian Jessie is LXDE however I may be mistaken.
I would also recommend backup your image just in case.
Alternatively, you could install Raspbian and PiAware manually. There are easy to follow instructions on the forum that I used for my RPi3, I’ve got a GUI and all.
