PiAware Automatic updates
If/When Flightaware pushes out an automatic update, is it a image or a patch?
For example are wireless parameters, etc. saved on update?.
It wouldn’t be an image - since that would need a mechanism to replace what’s on the SD card … but, I believe, they can update almost anything else
It’s a patch and won’t nuke your WiFi settings. That’s one of the big advantages of the auto-update vs installing a new image.
Thanks - that is the answer I wanted. Going to install a couple pi’s hundreds of miles away and it’s all about minimum local site maintenance.
Will the auto update work on the Piaware add on option. I am not using the SD card image.
Yes, if you ran this command:
sudo piaware-config -autoUpdate 1 -manualUpdate 1
