Post new topic Reply to topic  [ 16 posts ]
Author Message
 Post subject: PiAware 3.0 package-based installation
PostPosted: Wed Sep 07, 2016 11:37 am
Offline
FlightAware Staff
ericcarlson - FlightAware user avatar
Note this is for advanced users. The simplest way to install/setup PiAware is by using the image-based SD card install. See the PiAware 3 announcement thread.
If you would like to do a package-based install of PiAware on an existing Raspberry Pi, you may now do so. The instructions for a package-based install are available on our PiAware Installation page.
(If you are interested in PiAware 2 in-place upgrades, we will have an announcement about that option in the coming days.)
Thanks for your interest in PiAware!
Top
 Profile
 Post subject: Re: PiAware 3.0 package-based installation
PostPosted: Fri Sep 16, 2016 7:42 am
Offline
thehowieee - FlightAware user avatar
Any update (even if no update yet) on PiAware2 in-place upgrades to 3.0.x?
Top
 Profile
PostPosted: Fri Sep 16, 2016 9:03 am
Offline
FlightAware Staff
Yes, I am able to announce today the availability of PiAware 2 upgrades to PiAware 3! Please see the upgrade announcement thread.
Top
 Profile
PostPosted: Fri Sep 16, 2016 9:06 am
Offline
:D :D :D :D :D :D :D :D :D :D :D :D :D
thanks!
Top
 Profile
PostPosted: Sun Sep 18, 2016 11:23 am
Offline
SacScanner - FlightAware user avatar
Does this package contain the wireless wifi configuration? If not, what's the command for it? I'm new here and new to Raspberry Pi. I've got the Pi3 with Raspbian loaded (via Noobs), so I'm thinking just type in the package commands in terminal and get PiAware 3. Correct? And thanks.
Top
 Profile
PostPosted: Sun Sep 18, 2016 12:25 pm
Offline
FlightAware Member
elpipila - FlightAware user avatar
Start here. You will write your card with a package that includes everything you need. the how to instructions and links for your wifi configuration are also at this link
ads-b-flight-tracking-f21/announcing-piaware-3-latest-version-3-0-4-t37681.html
Top
 Profile
PostPosted: Tue Sep 20, 2016 11:32 am
Offline
Charter Member
ylinen - FlightAware user avatar
Ok, I downloaded the 3.0.4 img version. Put it on an SD card. When I hook an HDMI to the PI; it says "Mode Not Supported". It worked on PiAware 2.0.5 just fine. Did you take the HDMI capability out of the image?
I need to configure my wifi. When I look on the SD card there are no folders other than OVERLAYS on a PC. How do I configure the PiAware for wifi if I can't see anything with HDMI and there are no files.
Top
 Profile
PostPosted: Tue Sep 20, 2016 12:21 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
HDMI is still enabled. There are definitely many files on the first FAT partition. You may want to try rewriting the image. There is another thread for image-based installs.
Top
 Profile
PostPosted: Sat Sep 24, 2016 3:05 am
Offline
hughjmilsom - FlightAware user avatar
Really enjoying 3.1.0 - thank you so much! The display is great ...
Hugh
PS I'm unable to get Bing back .. have I missed something?
hjm
Top
 Profile
PostPosted: Sat Sep 24, 2016 5:35 am
Offline
FlightAware Member
Install 1: upgraded 3.0.5 (SD card) to 3.1.0 from my Stats page by giving command to device.
Install 2: formatted microSD card and burned "piaware-sd-card.3.1.0.img".
Both are FANTASTIC.
Top
 Profile
PostPosted: Sat Sep 24, 2016 6:26 pm
Offline
FlightAware Member
jcinnb - FlightAware user avatar
Do you take your SD card out and take image offline, or do you do it while RPi is running?
Top
 Profile
PostPosted: Wed Oct 26, 2016 1:08 am
Offline
mt007 - FlightAware user avatar
Hi guys,
when new update for PiAware 3.0?
Is not possible add more info in that webpage?
I want add for example: icao aircraft type in table.
Any idea how we can do that?
Thanks very much.
Regards,
Miguel
Top
 Profile
PostPosted: Wed Oct 26, 2016 12:40 pm
Offline
FlightAware Member
toverfield - FlightAware user avatar
The easiest way is to press the "Expand Sidebar" button in the upper right corner of the map page. This will hide the map, but it will show all of the columns.
It is an easy edit to also show the aircraft type in the split screen map. You will need to know how to log into the pi and change a text file.
Use putty or ssh to log into the pi. Edit the file: /usr/share/dump1090-fa/html/script.js
The function setColumnVisibility(), which starts at around line 1190 in script.js, hides some of the columns when the map is showing.
Add two slash characters, "//", to the appropriate line to prevent hiding that column. Note that I also chose to enable the registration column.
Code:
function setColumnVisibility() {
    var mapIsVisible = $("#map_container").is(":visible");
    var infoTable = $("#tableinfo");
//  showColumn(infoTable, "#registration", !mapIsVisible);
//  showColumn(infoTable, "#aircraft_type", !mapIsVisible);
    showColumn(infoTable, "#vert_rate", !mapIsVisible);
    showColumn(infoTable, "#rssi", !mapIsVisible);
Top
 Profile
PostPosted: Thu Oct 27, 2016 11:09 am
Offline
Thanks very much Tover.
Where Piaware goes take aircraft data information?
We have some basestation.spb inside?
I see in my webpanel aircraft without callsign, or hexcode or aircraft type, need to update, but where we can do that?
Regards,
Miguel
Top
 Profile
PostPosted: Fri Oct 28, 2016 2:24 pm
Offline
FlightAware Member
Built in.
The built-in database will probably be updated with each new release of the flightaware SD card image.
If you know how to download and use the files in dump1090/dev/tools (on github) then you can add your own custom entries to the csv file and rebuild the json files yourself.
Top
 Profile
PostPosted: Tue Jan 31, 2017 12:01 am
Offline
vasudevanmca - FlightAware user avatar
i have pi3B and isntalled PiAware3.0 package via wifi connection
Top
 Profile
Who is online
Users browsing this forum: david.baker, jluebbe, MrNuke, tdrane and 1 guest
Search for:
Jump to:
