Post new topic Reply to topic  [ 242 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
Author Message
 Post subject: Orange Pi PC -- a $15 alternative to RPi 2? So far, so good
PostPosted: Thu Nov 26, 2015 1:08 am
Offline
gismonkey - FlightAware user avatar
A low cost single board computer called the Orange Pi PC hit the market a few months ago for a list price of $15 (bare board, no power/microSD/case):
http://www.orangepi.org/orangepipc/
It's got a quad-core 1.5Ghz ARM7 cpu (Allwinner H3) and 1GB of RAM, so on paper it should give the RPi 2 a serious run for its money. At any rate, I bought one to see if I could use it as a cheap Pi alternative; it shipped very quickly and is a pretty nice board. They don't support power over the micro USB connector, so I'm using an old Sony PSP 5V 2A adapter I got at Goodwill for $2 and a Samsung 32GB microSDHC card I swiped out of an RPi.
So far, so good. Software support for the Orange Pi boards is pretty spotty, but there's a Lubuntu Mate disk image that works well. I installed the Flightaware version of dump1090 and the PiAware package, and it seems to be ticking along just fine. Both the Orange Pi and RPi 2 are using ARMv7 processors, so there's no need to recompile. Dump1090 is using ~25% of one CPU core.
It's running as Site 15626. I'm using the same super-cheap RTL820T receiver and 69mm whip antenna I was using on my RPi (site 7950). If I get really enthusiastic I'll try a wifi dongle on it. I'll probably let it run for a week or two then switch back to my RPi, as I really want to test what this board can do as a bittorrent client or an OpenVPN gateway.
Top
 Profile
 Post subject: Re: Orange Pi PC -- a $15 alternative to RPi 2? So far, so
PostPosted: Thu Nov 26, 2015 2:15 am
Offline
FlightAware Member
ieand - FlightAware user avatar
Yep, they are good bang for the bucks.
I have a Opi PC here running Debian Jessie (headless) with 3 RTL sticks for ADSB, ACARS and RTL_TCP for air-band radio and general listening.
The lack of proper drivers for the video hardware rule them out for a lot of stuff but they make great little servers.
Top
 Profile
PostPosted: Thu Nov 26, 2015 5:42 am
Offline
FlightAware Staff
obj - FlightAware user avatar
Beware that they don't have consistently unique MAC addresses, which will cause all sorts of problems with piaware if you get a collision.
Top
 Profile
PostPosted: Thu Nov 26, 2015 6:15 am
Offline
FlightAware Member
OK thanks. That is quite an issue.
Is there anything that can be done to avoid a conflict?
Top
 Profile
PostPosted: Thu Nov 26, 2015 8:51 am
Offline
FlightAware Staff
I don't know how widespread it is, or the exact cause. I've seen it once so far, with two piawares with identical MACs, and there are only few of them running piaware so either we were really unlucky or it is relatively common. We assume implicitly that MACs are unique (they're meant to be!), so it's a bit horrible to deal with. If it does happen you will have to override the MAC manually, but first you have to notice the problem (it manifests as all the traffic from both piawares being counted towards the first site to register). If you ever got them on the same ethernet segment, it would cause all sorts of chaos too..
Top
 Profile
PostPosted: Thu Nov 26, 2015 12:18 pm
Offline
FlightAware Member
caius - FlightAware user avatar
The Raspberry Pi foundation have just released a new model stripped down model costing $5. It uses the same processor as the original Pi, but running at a higher clock speed. It only has power, a single micro USB and micro HDMI connectors, but that is enough for running adsb stuff through a hub.
Top
 Profile
PostPosted: Thu Nov 26, 2015 12:25 pm
Offline
FlightAware Member
joelwiley - FlightAware user avatar
Just in time for Black Friday, Raspberry Pi Zero released for $5. http://abcnews.go.com/Technology/raspbe ... d=35432176
or buy the MagPi mag issue #40, it comes with the computer https://www.raspberrypi.org/magpi/issues/40/
"There is only one step from the sublime to the ridiculous." - Napoleon Bonaparte
Top
 Profile
PostPosted: Thu Nov 26, 2015 9:41 pm
Offline
FlightAware Member
Thanks, handy to know.
I'm surprised you don't see it more often as some of the network card vendors of old had a habit of recycling the addresses of cards they where shipping into different markets, after all MAC addresses cost money and they figured they where unlikely to ever show up on the same network and cause a problem.
Anyway might mention it on the OPI forum and see if there is any response.
Top
 Profile
PostPosted: Thu Nov 26, 2015 11:45 pm
Offline
FlightAware Member
Which MAC address does piaware use too identify a receiver? Is it the built in Ethernet adaptor, or the active interface?
Top
 Profile
PostPosted: Fri Nov 27, 2015 5:44 am
Offline
FlightAware Staff
It is always the Ethernet MAC.
Top
 Profile
PostPosted: Fri Nov 27, 2015 7:30 am
Offline
FlightAware Member
What happens with a device like the pi zero without a built in NIC?
Top
 Profile
PostPosted: Fri Nov 27, 2015 8:20 am
Offline
FlightAware Staff
If there's no eth0 then piaware probably breaks.
Top
 Profile
PostPosted: Fri Nov 27, 2015 11:04 am
Offline
FlightAware Member
dschaper - FlightAware user avatar
All RasPi's have a MAC burned, even if they have no RJ45.
Top
 Profile
PostPosted: Fri Nov 27, 2015 2:46 pm
Offline
FlightAware Member
Kabuse - FlightAware user avatar
Please bring a source for this information, otherwise it is just bullshit.
A media access control address (MAC address), also called physical address, is a unique identifier assigned to network interfaces for communications on the physical network segment.
Source -> https://en.wikipedia.org/wiki/MAC_address
No network interface -> no MAC address
Kabuse
Top
 Profile
PostPosted: Fri Nov 27, 2015 5:00 pm
Offline
FlightAware Staff
Well, IIRC the Pis derive their MACs from the Pi serial number; I guess that Pi As and zeros still have a serial number.
Code:
pi@tau ~ $ cat /proc/cpuinfo | grep Serial
Serial      : 00000000f5464627
pi@tau ~ $ ifconfig eth0 | grep HWaddr
eth0      Link encap:Ethernet  HWaddr b8:27:eb:46:46:27
Top
 Profile
PostPosted: Sat Nov 28, 2015 4:07 am
Offline
One minor update: I found that if the OpenVPN client was running, PiAware would crash without notice. Without OpenVPN, no problems.
Weird, but I really like this hardware! Lots of power for little money. I'm not sure what to do about the MAC address issue; if I replace my RPis with them, I'll just clone the MAC off the RPi to the Orange Pi.
Top
 Profile
PostPosted: Sat Nov 28, 2015 7:01 am
Offline
FlightAware Staff
It would be good to know why piaware was crashing (check the piaware logs?)
Top
 Profile
PostPosted: Sat Nov 28, 2015 9:02 am
Offline
FlightAware Member
Kabuse
I have a feeling unless I mailed you my Compute or my Zero you'd claim I was talking bullshit, so I acquiesce, you win, here's your cookie...
https://www.raspberrypi.org/forums/view ... 98&t=80016
Top
 Profile
PostPosted: Sat Nov 28, 2015 3:12 pm
Offline
FlightAware Member
Top
 Profile
PostPosted: Sat Nov 28, 2015 6:03 pm
Offline
FlightAware Member
Bahahaha, that's classic!
Top
 Profile
PostPosted: Sat Nov 28, 2015 7:22 pm
Offline
FlightAware Member
jepolch - FlightAware user avatar
I bought an Orange Pi today to get a chance to play with another single board computer. Looking forward to receiving it. I hope I don't live to regret giving Aliexpress my CC number! :lol:
Top
 Profile
PostPosted: Sat Nov 28, 2015 10:23 pm
Offline
FlightAware Member
Hahaha....jepolch, we think the same way.
Last night after filling all details at Aliexpress, when I reached the point where I had to ente my Credit Card number, I hesitated, and finally cancelled everything. May be I am too skeptical, or addicted to eBay/Amazon/Paypal. But I have not yet given up idea of buying an Orange Pi. May be in few days I gather enough courage to give my CC number to Aliexpress. The $15 Orange Pi is so alluring!
Top
 Profile
PostPosted: Sun Nov 29, 2015 2:19 am
Offline
FlightAware Member
I've bought probably 6 or 7 times via AB over the years including the OrangePI PC, so far (fingers crossed) with no problems. They are now such a seriously large organization, in Asia at least that the credit card providers couldn't afford to allow too much BS.
Their biggest downside I know of is the lack of support if the item purchased turns out to be rubbish but i guess at 15$ for the OPI PC thats not too big a problem.
jepolch, Which one did you get?
Top
 Profile
PostPosted: Sun Nov 29, 2015 8:52 am
Offline
FlightAware Member
ieand wrote:
I've bought probably 6 or 7 times via AB over the years including the OrangePI PC, so far (fingers crossed) with no problems...........
I have decided to place order to Alibaba Express for Orange Pi today. ieand & jepolch taking bold steps boosted my morale. Actually the name "Alibaba" rang warning bells in my mind because of my childhood story "Ali Baba & 40 Thieves" from ancient story book "One Thousand & One Nights", also known as "Arabian Nights" :).
https://en.wikipedia.org/wiki/Ali_Baba
Top
 Profile
PostPosted: Sun Nov 29, 2015 12:30 pm
Offline
FlightAware Member
abcd567 wrote:
Actually the name "Alibaba" rang warning bells in my mind because of my childhood story "Ali Baba & 40 Thieves" .
Just remember, AliBaba was the 'good guy' in the story. :)
Top
 Profile
Who is online
Users browsing this forum: k6rtm and 1 guest
Search for:
Jump to:
