Post new topic Reply to topic  [ 245 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10
Author Message
 Post subject: Re: Orange Pi PC -- a $15 alternative to RPi 2? So far, so
PostPosted: Sat Nov 19, 2016 6:16 pm
Offline
FlightAware Member
@mcrieman:
Testing installation of dump1090-fa on Armbian
I just now finished:
(1) Formatted spare microSD card
(2) On formatted microSD card wrote "Armbian_5.20_Orangepipc_Debian_jessie_3.4.112_desktop.img".
(3) Inserted microSD card in OrangePi PC, booted, changed password, created user pi and added it to sudo group.
(4) Spoofed MAC address to original MAC on which I feed Flightaware and have configured my Router to provide a static address for OrangePi.
(5) Rebooted and logged-in as user pi
(6) Run JP's auto install script and installed:
    (a) dump1090-fa + Piaware data feeder
    (b) Planefinder data feeder
    (c) Flightradar24 data feeder
    (d) Adsbexchange data feeder & mlat client
(7) Added "blacklist dvb_usb_rtl2832u" and "blacklist dvb_usb" to file /etc/modprobe.d/rtl-sdr-blacklist.conf
(8) Rebooted
(9) Configured Web Portal (<IP of OrangePI>/install)
(10) Checked dump1090 map - OK
(11) Checked Web Portal graphs - OK ( had to run command "sudo ~/adsb-receiver/build/portal/graphs/make-collectd-graphs.sh 24h" to populate the graphs, and do workaround for temprature graph)
(12) Checked Flightaware statistics page - OK
(13) Configured Planefinder (<IP of OrangePI>:30053) - OK
(14) Checked Flightradar 24 status (<IP of OrangePI>:8754) - OK
ALL WORKING WELL
UPDATE:
Checked gain setting, found ZERO ( 0 )
pi@orangepipc:~$ sudo systemctl status dump1090-fa
Loaded: loaded (/lib/systemd/system/dump1090-fa.service; enabled)
Active: active (running) since Sun 2016-11-20 00:50:09 CET; 5min ago
Main PID: 431 (dump1090-fa)
└─431 /usr/bin/dump1090-fa --device-index 0 --gain -10 --ppm 0 --net-bo-port 30005 --max-range 300 --net ...
Nov 20 00:50:09 orangepipc dump1090-fa[431]: Using sample converter: UC8, integer/table path
Nov 20 00:50:09 orangepipc dump1090-fa[431]: Found 1 device(s):
Nov 20 00:50:09 orangepipc dump1090-fa[431]: 0: Realtek, RTL2838UHIDIR, SN: 00000001
Nov 20 00:50:09 orangepipc dump1090-fa[431]: Using device 0: Generic RTL2832U OEM
Nov 20 00:50:09 orangepipc dump1090-fa[431]: 0: Realtek, RTL2838UHIDIR, SN: 00000001 (currently selected)
Nov 20 00:50:09 orangepipc dump1090-fa[431]: Found Rafael Micro R820T tuner
Nov 20 00:50:09 orangepipc dump1090-fa[431]: Closest available gain: 0.00 dB
Nov 20 00:50:09 orangepipc dump1090-fa[431]: Setting gain to: 0.00 dB
Nov 20 00:50:09 orangepipc dump1090-fa[431]: Gain reported by device: 0.00 dB
Tried to adjust gain by command sudo piaware-config rtlsdr-gain 48, and restart dump1090-fa, and it crashed! rebooted, still no planes, no data.
I tried sevveral gai n alues. Eery time I set a value and check in file /etc/piaware.conf the value of gain is same as I set last, but when dump1090-fa is restarted, and its status checked, the value of gain is shown NEGATIVE, and then the rtlsdr is set to nearest gain which is zero.
Top
 Profile
PostPosted: Sat Nov 19, 2016 7:51 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
The piaware-config rtlsdr-gain setting is only used if you are running a piaware sdcard image.
If you just have the dump1090-fa package and not the rest of the sdcard infrastructure, you should edit /etc/default/dump1090-fa directly.
Top
 Profile
PostPosted: Sat Nov 19, 2016 11:05 pm
Offline
FlightAware Member
@obj
Thanks Oliver, it worked. I dont know how gain got set to a negetive value (-48) before I edited it and removed negetive sign.
pi@orangepipc:~$ sudo nano /etc/default/dump1090-fa
#removed negetive sign from value of gain, and saved file.
pi@orangepipc:~$ sudo systemctl restart dump1090-fa
pi@orangepipc:~$ sudo systemctl status dump1090-fa -l
Active: active (running) since Sun 2016-11-20 04:55:40 CET; 7s ago
Main PID: 6688 (dump1090-fa)
└─6688 /usr/bin/dump1090-fa --device-index 0 --gain 48 --ppm 0 --net-bo-port 30005 --max-range 300 --net --net-heartbeat 60 --net-ro-size 1000 --net-ro-interval 1 --net-ri-port 0 --net-ro-port 30002 --net-sbs-port 30003 --net-bi-port 30004,30104 --net-bo-port 30005 --json-location-accuracy 1 --lat 43.5xxx --lon -79.6xxx --write-json /run/dump1090-fa --quiet
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: Sun Nov 20 04:55:40 2016 CET dump1090-fa v3.1.0 starting up.
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: Using sample converter: UC8, integer/table path
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: Found 1 device(s):
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: 0: Realtek, RTL2838UHIDIR, SN: 00000001
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: Using device 0: Generic RTL2832U OEM
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: 0: Realtek, RTL2838UHIDIR, SN: 00000001 (currently selected)
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: Found Rafael Micro R820T tuner
Nov 20 04:55:40 orangepipc dump1090-fa[6688]: Setting gain to: 48.00 dB
Nov 20 04:55:41 orangepipc dump1090-fa[6688]: Gain reported by device: 48.00 dB
pi@orangepipc:~$
All Working OK Now
Top
 Profile
PostPosted: Sat Nov 19, 2016 11:24 pm
Offline
mcrieman - FlightAware user avatar
@abcd567
I made a clean sd card image, used the install script as suggested. Everything installed ok but will not reboot with the receiver attached. The same receiver works on my Raspberry PI Flightaware setup. When it tries to boot in the graphical interface the screen goes blank, the green light on the board goes off and nothing further happens. I've tried multiple power adapters and sd cards. Maybe I just got a very touchy, poorly made Orange PI PC board??? I'm at a loss as to what to try next. Thanks for your help.
UPDATE: I tried yet another power adapter (believe it or not only a 1A for an Amazon Kindle). Now the system boots and everything appears to be working. Thanks again for all of your help. I really appreciate it. This board has been very frustrating. I guess my expensive power adapter doesn't hold a steady enough voltage.
Imageimg host
Top
 Profile
PostPosted: Sun Nov 20, 2016 11:38 am
Offline
Now that I have the Orange PI working with Piaware and dump1090-mutability thanks to help from users on this forum I am seeing many more airplanes than I did with Flightaware's Raspberry PI image. Is this due to the way the script set the receiver sensitivity? The antenna is in the exact same location as when the Raspberry PI was running the Piaware software.
Top
 Profile
PostPosted: Sun Dec 25, 2016 7:47 pm
Offline
WarrnamboolCity - FlightAware user avatar
I have been getting dropouts on my orangepipc. One thing I noticed was when I could not access the web IP address I coulalso could not use ssh to log in to the Pi. I also noticed if there was a dropout of Dump1090-fa the Armbian CPU temp was up around 65°C. It normally sits in the high 40's low 50's.
I tried the following to reduce CPU speed n the hope the temperature would lower:
http://www.orangepi.org/orangepibbsen/f ... ad&tid=785
Quote:
wget -O /usr/local/bin/fix-thermal-problems.sh "http://kaiser-edv.de/tmp/H9rWPf/fix-thermal-problems.sh"
Chmod 755 /usr/local/bin/fix-thermal-problems.sh
I then just tried the following and entering 1000000 in the MAX CPU FREQ
https://docs.armbian.com/User-Guide_Fine-Tuning/
Quote:
nano /etc/default/cpufrequtils
service cpufrequtils restart
Yet I still get dropouts and not being able to access via ssh. Other than that I have been pulling in a few distances over 300nm, 363 nm my best to date using a yagi with FA PRO STICK. Given it is pointing over ocean and it is our summer it will only be skip through inversion layers I guess.
Any suggestions as to tests? It is a chinese power supply with a usb recepticle (2000ma).
Top
 Profile
PostPosted: Tue Jan 03, 2017 3:35 pm
Offline
FlightAware Member
idh - FlightAware user avatar
Looking at those instructions, the 2nd line won't work as it is shown - needs to be with a lower case "c" to chmod.
But all that has done so far is download the fix and make it executable. You still need to run the fix.
Code:
It will tell you to wait while it fixes the possible problem (runaway temperatures).
But 65°C should not be a problem - I've seen 80°C during our UK summer
Top
 Profile
PostPosted: Tue Jan 03, 2017 3:44 pm
Offline
FlightAware Member
More likely the power supply - there have been concerns about whether they are any good - are they really 2000ma?
I'm running my OrangePi PC from something like this [url][/http://www.ebay.co.uk/itm/2A-Dual-USB-Mains-Wall-3-Pin-Plug-Adaptor-Charger-Folding-for-Phones-and-Tablet-/262101378709url] with a cable like this [url]http://www.ebay.co.uk/itm/New-Black-USB-Cable-Charger-Lead-For-Xbox-360-Wireless-Headphone-Headset-/172055736976[/url]
NEED TO CHECK this is correct cable version. I bought one of these but might have been for a tablet or maybe they are the same :oops:
Top
 Profile
PostPosted: Tue Jan 03, 2017 4:30 pm
Offline
IDH
The OPi seems to have responded to your commands. Lets see what happens.
It has been very intermittent over the last week. It would not last a few hours before the thing would freeze up( not accessible via ssh). Having said that, my RPi has frozen a couple of times and it has the RPi power supply. I will get a 2500ma power supply and see if that fixes the problem. Thanks for the tip.
Top
 Profile
PostPosted: Mon May 01, 2017 2:04 pm
Offline
FlightAware Member
UPDATE - May 01, 2017
Recommended: Armbian version 5.20 from archieves
Tried last 3 versions of Armbian. Results are as follows:
(1) Armbian_5.25_Orangepipc_Debian_jessie_default_3.4.113
(a) Piaware 3.5.0 and dump1090-fa work ok and feed data to Flightaware.
(b) Lighttpd fails, and as a result map page Skyview and Piaware Radio Status pages are not displayed.
(2) Armbian_5.24_Orangepipc_Debian_jessie_default_3.4.113
(3) Armbian_5.20_Orangepipc_Debian_jessie_3.4.112_desktop
(b) Lighttpd works OK, Map page Skyview is displayed OK
(c) Piaware Radio Status pages is not displayed. Instead Placeholder page of lighttpd is displayed.
Note:
to make dump1090-fa work, in file /etc/modprobe.d/rtl-sdr-blacklist.conf, add the lines below, and reboot.
blacklist dvb_usb
Top
 Profile
PostPosted: Mon May 01, 2017 3:52 pm
Offline
FlightAware Member
Thanks to Oliver for his following comments about Radio Status Page:
obj wrote:
The top-level status page is only present on piaware sdcard installs.
If you want to install it on something else, try installing the piaware-web package (but it will take over the top-level page, and it assumes it is running on a sdcard image, so YMMV)
Top
 Profile
PostPosted: Mon May 01, 2017 4:23 pm
Offline
atriasgr - FlightAware user avatar
Hello
Thank you for the info
What is the Radio Status Page ?
Top
 Profile
PostPosted: Mon May 01, 2017 4:54 pm
Offline
FlightAware Member
atriasgr wrote:
Hello
This is the Radio Status Page from version 3.1, but page for version 3.5 is almost same.
There are 4 buttons (Radio, Piaware, Flightaware, and MLAT).
If the color of a button is green, that function is OK.
If the color is orange, the function is not working .
Top
 Profile
PostPosted: Tue May 02, 2017 4:03 pm
Offline
thank you
Top
 Profile
PostPosted: Wed May 03, 2017 2:31 am
Offline
FlightAware Member
Raised the issue of lighttpd failure on "Armbian_5.25_Orangepipc_Debian_jessie_default_3.4.113" in Armbian Forums.
Got following reply:
Igor wrote:
Its a bug in ramlog ... which is fixed in dev version. Disable it and install again or move to nightly build and install again.
Igor wrote:
Or disable ramlog and recreate logs manually and start web server again.
Now the question is: How to disable ramlog? Where is it located?
https://forum.armbian.com/index.php?/to ... ault_34113
Top
 Profile
PostPosted: Wed May 03, 2017 3:47 pm
Offline
they answered already that you can disable it in /etc/default/log2ram
but I would add that by disabling it I guess the logs will be written to files in your SD card
but you can find these logs and make them a link to /dev/null so that no logs will be written
Code:
ln -s /dev/null /path/to/logfile
Top
 Profile
PostPosted: Thu May 04, 2017 12:01 pm
Offline
FlightAware Member
@atriasgr:
Thank you.
Top
 Profile
PostPosted: Fri Jun 30, 2017 11:18 am
Offline
TomNJerry - FlightAware user avatar
UPDATE June 30, 2017
Today downloaded and wrote following latest Armbian images:
Armbian_5.30_Orangepipc_Ubuntu_xenial_default_3.4.113.img
Armbian_5.30_Orangepipc_Debian_jessie_default_3.4.113.img
BOTH distros give following problem:
(1) With dump1090-mutability ver1.15~dev
  • dump1090-mutability is running
  • lighttpd is running
  • map at <IP of Pi>/dump1090/gmap.html gives warning:
    "Problem fetching data from dump1090. AJAX call failed (error: Not Found). Maybe dump1090 is no longer running? The displayed map data will be out of date."
(2) With dump1090-fa
  • dump1090-fa fails
(Note: In text below, I had to insert spaces before and after all slashes / to prevent "Forbidden" when clicked preview or submit buttons)
pi@orangepipc:~$ sudo systemctl status lighttpd -l
[sudo] password for pi:
lighttpd.service - Lighttpd Daemon
Loaded: loaded (/ lib / systemd / system / lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2017-06-30 15:49:58 UTC; 18min ago
Process: 2902 ExecStartPre= / usr / sbin / lighttpd -t -f / etc / lighttpd / lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 2908 (lighttpd)
CGroup: / system.slice / lighttpd.service
└─2908 / usr / sbin / lighttpd -D -f / etc / lighttpd / lighttpd.conf
Jun 30 15:49:58 orangepipc systemd[1]: Starting Lighttpd Daemon...
Jun 30 15:49:58 orangepipc lighttpd[2902]: Syntax OK
Jun 30 15:49:58 orangepipc systemd[1]: Started Lighttpd Daemon.
pi@orangepipc:~$ sudo systemctl status dump1090-mutability -l
dump1090-mutability.service - LSB: dump1090 daemon (mutability variant)
Loaded: loaded ( / etc / init.d / dump1090-mutability; bad; vendor preset: enabled)
Active: active (exited) since Fri 2017-06-30 15:50:05 UTC; 18min ago
Docs: man:systemd-sysv-generator(8)
Process: 2926 ExecStop= / etc / init.d / dump1090-mutability stop (code=exited, status=0/SUCCESS)
Process: 2934 ExecStart= / etc / init.d / dump1090-mutability start (code=exited, status=0/SUCCESS)
Jun 30 15:50:04 orangepipc systemd[1]: Starting LSB: dump1090 daemon (mutability variant)...
Jun 30 15:50:05 orangepipc systemd[1]: Started LSB: dump1090 daemon (mutability variant).
Top
 Profile
PostPosted: Fri Jun 30, 2017 2:07 pm
Offline
After installation of Piaware Data feeder (add on package)
● dump1090-mutability.service - LSB: dump1090 daemon (mutability variant)
Loaded: loaded (/ etc / init.d / dump1090-mutability; bad; vendor preset: enabled)
Active: active (exited) since Fri 2017-06-30 18:59:40 UTC; 3min 59s ago
Process: 697 ExecStart= / etc / init.d / dump1090-mutability start (code=exited, status=0/SUCCESS)
Jun 30 18:59:38 orangepipc systemd[1]: Starting LSB: dump1090 daemon (mutability variant)...
Jun 30 18:59:40 orangepipc systemd[1]: Started LSB: dump1090 daemon (mutability variant).
pi@orangepipc:~$ sudo systemctl status piaware -l
Loaded: loaded (/ lib / systemd / system / piaware.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2017-06-30 18:59:38 UTC; 4min 10s ago
Main PID: 689 (piaware)
CGroup: / system.slice / piaware.service
└─689 / usr / bin / piaware -p / run / piaware / piaware.pid -plainlog -statusfile / run / piaware / status.json
Jun 30 19:01:42 orangepipc sudo[1406]: pam_unix(sudo:session): session closed for user root
Jun 30 19:01:42 orangepipc piaware[689]: no ADS-B data program seen listening on port 30005 for 124 seconds, next check in 60s
Jun 30 19:02:42 orangepipc sudo[1647]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND= / bin / netstat --program --tcp --wide --all --numeric
Jun 30 19:02:42 orangepipc sudo[1647]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 30 19:02:42 orangepipc sudo[1647]: pam_unix(sudo:session): session closed for user root
Jun 30 19:02:42 orangepipc piaware[689]: no ADS-B data program seen listening on port 30005 for 184 seconds, next check in 60s
Jun 30 19:03:42 orangepipc sudo[1858]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/ bin / netstat --program --tcp --wide --all --numeric
Jun 30 19:03:42 orangepipc sudo[1858]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 30 19:03:42 orangepipc sudo[1858]: pam_unix(sudo:session): session closed for user root
Jun 30 19:03:42 orangepipc piaware[689]: no ADS-B data program seen listening on port 30005 for 244 seconds, next check in 60s
Top
 Profile
PostPosted: Sat Jul 01, 2017 3:53 am
Offline
FlightAware Member
I replicated your install and faced the same problem.
I solved it by following method. All is now working OK.
Code:
#open file rtl-sdr-blacklist.conf in an editor
sudo nano /etc/modprobe.d/rtl-sdr-blacklist.conf
# This system has librtlsdr0 installed in order to
# use digital video broadcast receivers as generic
# software defined radios.
blacklist dvb_usb_rtl28xxu
blacklist e4000
blacklist rtl2832
#add these two line below the last line in the file:
blacklist dvb_usb
#save file and reboot
Top
 Profile
Who is online
Users browsing this forum: aenea and 1 guest
Search for:
Jump to:
