Post new topic Reply to topic  [ 242 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
Author Message
 Post subject: Re: Orange Pi PC -- a $15 alternative to RPi 2? So far, so
PostPosted: Mon Jun 13, 2016 9:53 am
Offline
FlightAware Member
cy80rg - FlightAware user avatar
Thanks @Johnhawkes2030 - isnt that the same as "bind to all" in the dump1090 setup?
I'll check that file as you say...
I always set to "bind to all=yes" (pig-scripting!) on each of my setups, this is the first time I've had this...
Also, came across this - which *shouldnt* be the issue, but I'll check anyway...
"That the /etc/hostname file contains just the name of the machine.
That /etc/hosts has an entry for localhost. It should have something like:
127.0.0.1 localhost.localdomain localhost
127.0.1.1 my-machine
*EDIT - I did "bind to all=yes" on my main receiver (which is also running) as well as this Opi (which isnt connected to an ant etc, just setting up to see if it works).
Could the issue be that *both* receivers are "bound to all" at the same time?
Top
 Profile
PostPosted: Mon Jun 13, 2016 1:50 pm
Offline
FlightAware Member
cy80rg wrote:
....Could the issue be that *both* receivers are "bound to all" at the same time?
I dont think so, these are independent receivers.
Top
 Profile
PostPosted: Tue Jun 14, 2016 12:01 pm
Offline
FlightAware Member
Strange...
Ive got /etc/hosts open in nano...
I leave it ope for a few minutes, then the first line
Quote:
127.0.0.1 localhost orangepipc
over writes itself with
Quote:
(UNKNOWN) [127.0.0.1] 30005 (?) : Connection refused
Leaving it open for a few minutes longer, that same line keeps appearing (While om watching it) - in that file.
Would I be right in thinking this is that file updating from an external source (process / service etc) while Im in it?
Top
 Profile
PostPosted: Tue Jun 14, 2016 1:02 pm
Offline
FlightAware Member
@cy80rg
What you described seems to be an output from a script trying to connect to 127.0.0.1:30005, and failing, then retrying.
Top
 Profile
PostPosted: Wed Jun 15, 2016 3:31 am
Offline
FlightAware Member
Thanks abcd567 - I think you're right.
I'm looking to uninstall ADSB-Receiver and it's releated bits - get back to a clean Armbian image and start again...
Top
 Profile
PostPosted: Wed Jun 15, 2016 4:12 am
Offline
FlightAware Member
@cy80rg:
It may be caused by adsbexchange connection script using netcat to connect. You can disable this scrip by commenting out all the lines:
Quote:
:~$ sudo nano adsb-receiver/build/adsbexchange/adsbexchange-maint.sh
#contents of the file below. Comment out all lines
#! /bin/sh
while true
do
sleep 30
/bin/nc 127.0.0.1 30005 | /bin/nc feed.adsbexchange.com 30005
done
Top
 Profile
PostPosted: Fri Jun 17, 2016 11:25 am
Offline
FlightAware Member
thanks @abcd567 - doing complete install from formatted-SD up, as we speak.
Understand re ADSBExchange - I'll not install that this time round.
Do we know why that does that - is there a fix, or does ADSBExchange simply not work on the OPi?
Top
 Profile
PostPosted: Fri Jun 17, 2016 1:08 pm
Offline
FlightAware Member
adsbexchange does work on my OPi, but sometimes it has connection problem. This is however a temporary problem, and resolved in couple of hours by itself.
I am not sure on your install it was due to adsbexchange or something else. I suggest you make fresh install without adsbexchange and watch. If all ok, add adsbexchange and watch again. If the problem appears, leave it for couple of hours, it may disappear. If it does not disappear, then disable adsbexchange-maint script.
Top
 Profile
PostPosted: Fri Jun 17, 2016 1:19 pm
Offline
FlightAware Member
Hi all,
K - reinstalled from a blank SD card up, all looking better, but no dump1090 data
- Installation went as expected (though as before, couldnt set up PlaneFinder at http://orangepicpc:30053 - had to go to http://<localIpOfOrangePi>:30053).
- Sorted out the missing core temp data as abcd567 details
So, as expected - the system data UI is now working, dump1090 graphs and live map data isnt.
Dump1090 System UI - Broken image icons
Dump1090 Map UI - No birds shown, map loaded on arbitrary point, errMsg suggesting Dump1090 isnt running.
Went through abcd567's suggestions:
Quote:
(2) DUMP1090 not working (RTL problem in version 3.4.112)
Looks like Jo's added this blacklist in the last ADSB-R, has the following already there:
Code:
# software defined radios.
blacklist dvb_usb_rtl28xxu
blacklist e4000
blacklist rtl2832
blacklist dvb_usb
However,
Code:
~$ sudo lsmod | grep rtl
...shows...
Code:
dvb_usb_rtl2832u      351091  0
dvb_usb                15734  1 dvb_usb_rtl2832u
which to me suggests these are actually loaded, despite the blacklist wildcards, which I believe should catch these?
NB - I'll try and explicitly add these, but I believe they're already covered?
Quote:
(5) Only one dvb-t plugged into Orange Pi, but both dump1090 & dump978 installed:
Deliberately didnt install dump978 - I only have one dongle / ant.
As such, that line wasnt there.
dump1090-mutability service reports as Active as expected... (usual "status" output).
Any thoughts?
Top
 Profile
PostPosted: Fri Jun 17, 2016 1:22 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
cy80rg wrote:
Code:
Code:
28xxu does not match 2832u.
Top
 Profile
PostPosted: Fri Jun 17, 2016 1:26 pm
Offline
FlightAware Member
Good man @Obj - just explicitly blacklisted that and "Thar be... birds!" (to paraphrase ;) ).
Are the "xx" not wild cards then?
Top
 Profile
PostPosted: Fri Jun 17, 2016 1:42 pm
Offline
FlightAware Staff
Nope, just how some version of the driver was named.
Top
 Profile
PostPosted: Fri Jun 17, 2016 1:43 pm
Offline
atriasgr - FlightAware user avatar
no "xx" are not widlcards
you have to write the module name exactly as shown in lsmod
Top
 Profile
PostPosted: Wed Jun 22, 2016 3:50 am
Offline
FlightAware Member
Thanks guys, got this up and running - plugged into habAmp, Ant and stable in attic :)
Out of interest, anyone done this on a C.H.I.P ?
(Just thinking of the cheapest possible way to get a station setup, so I can have multiple... the CHIP's c£15 incl PnP).
Top
 Profile
PostPosted: Wed Jun 22, 2016 4:33 am
Offline
gismonkey - FlightAware user avatar
Yeah, I've got a pair of C.H.I.P.s that I bought with this in mind and found them too unstable, underpowered, and finicky for this work. dump1090 and the various rtl_sdr tools install ok and recognize the receiver, but the board hangs as soon as I fire up dump1090. I messed around for quite a while with firmware/OS/drivers/power supplies and was never satisfied. It was a pretty disappointing outcome -- now I just have one of the C.H.I.P.s hooked to the analog input on my TV loading a ThingSpeak graph, and the other sitting in a box looking for a purpose (or new home).
The $10 Orange Pi One and $12 Orange Pi Lite both are looking really attractive now, though -- especially with the great work the Armbian folks are doing!
[EDIT -- Added 25 June 2016]
This comment spurred me to return to my C.H.I.P.s -- and I had a lot more success this time around. It turns out that folks working with C.H.I.P boards have identified a lot of the idiosyncrasies over the last few months and developed workarounds. The most important is that the on-board power management chip will shut it down if the C.H.I.P is drawing over 900 mA through the microUSB port, so we need to bypass the microUSB, disable the power management chip, or use a powered USB hub for peripherals and hope for the best. The C.H.I.P. itself can draw upwards of 1A under heavy load, too.
I have been able to get a C.H.I.P. with FlightAware Pro Stick up and running by using the powered USB hub (a Pluggable 4-port) that I was using to run my old Pi B to power the C.H.I.P. and the Pro Stick. I eventually got dump1090-mutability v1.14 up and running, more or less (had to edit /etc/init.d/dump1090-mutabillity line 68 due to a typo; I sent a pull request on github to fix it). The flightaware dump1090 package isn't working on my C.H.I.P. I also tried building rtl-sdr and dump1090 from source, which worked ok.
The piaware package appears to be working and happily feeds positions to FlightAware, but every time it reboots it creates a new site. It can't seem to decide which MAC address to use, as each time it reboots it creates a pair of virtual ethernet adapters at USB0 and USB1 with random MAC addresses (which PiAware then uses, even though WLAN0 is stable). Sigh. Back to the drawing board.
My C.H.I.P. is at about 32% CPU load for dump1090-mutability.
Top
 Profile
PostPosted: Tue Jul 19, 2016 6:37 am
Offline
WarrnamboolCity - FlightAware user avatar
I got an Orange PI PC plus. Some ammendments were made to Armbian earlier this month (July6th). The wifi is working and I have installed Dump 1090 Mutability only with the plane finder client at this stage. there were no issues in the install. Now I am just waiting for an aircraft to flyby so i can capture data.
Update: when I run this command: sudo /etc/init.d/dump1090-mutability status I get the following -
● dump1090-mutability.service - LSB: dump1090 daemon (mutability variant)
Loaded: loaded (/etc/init.d/dump1090-mutability)
Active: active (exited) since Wed 2016-07-20 06:18:09 AEST; 1h 33min ago
Process: 520 ExecStart=/etc/init.d/dump1090-mutability start (code=exited, status=0/SUCCESS)
Jul 20 06:18:09 orangepipcplus systemd[1]: Started LSB: dump1090 daemon (mut....
Hint: Some lines were ellipsized, use -l to show in full.
opi@orangepipcplus:~$
Top
 Profile
PostPosted: Sun Aug 07, 2016 7:34 am
Offline
FlightAware Member
usafpride - FlightAware user avatar
I now have 2 corrupted Transcend cards due to some unknown weird oPi issue. I have a rPi3 coming today and the oPi is going to be relegated to some other benign use. I'm hoping Transcend will RMA these cards.
Top
 Profile
PostPosted: Sun Aug 07, 2016 9:12 am
Offline
FlightAware Member
Are you sure it is due to Orange Pi? Lot of people having RPi also have complaint of corrupted/worn out cards. I dont think this issue is related to make or model of Pi.
I have Pi B+, Pi 2, and OPi PC. None of my microSD cards have corrupted or worn out, though each card has several times faced formatting and fresh install.
Top
 Profile
PostPosted: Sun Aug 07, 2016 12:14 pm
Offline
FlightAware Member
One card came out of a Pi 2, the other was brand new. The Pi2 with an old card is still trucking and that is feeding to LiveATC.net 100% of the time with pretty good load. I think the oPi is also getting taxed when the reports/sec get above 400.
Top
 Profile
PostPosted: Sat Nov 19, 2016 8:23 am
Offline
mcrieman - FlightAware user avatar
I installed Armbian on an Orange PI PC. Got that working smoothly. Installed dump1090-fa and piaware. Piaware is running, successully claimed and reporting data to Flightaware but dump1090-fa is not running. When I invoke it manually it says that the usb receiver is in use by another process. I have tried blacklisting it and also tried recompiling the sdr-rtl drivers to detach at bootup. None of that is working. If anyone has any suggestions I would appreciate it.
Top
 Profile
PostPosted: Sat Nov 19, 2016 9:49 am
Offline
FlightAware Member
@mcrieman
Please see on page 7 of this thread post titled "WORK AROUND FOR 5 ISSUES", item "(2) DUMP1090 not working".
To go to this post, click the link below:
post194971.html#p194971
Top
 Profile
PostPosted: Sat Nov 19, 2016 12:04 pm
Offline
abcd567 wrote:
@mcrieman
I was doing that but it wasn't working for me. I used the lsmod command to find the exact name I needed to blacklist which turned out to be "dvb_usb_rtl2832u". After I did that the Orange PI fails to boot. Once when it stopped I could see that dump1090 started successfully and for a brief time I could see it on my other computer by going to the webpage but then it stopped. Now I believe the issue is that once the receiver starts working it is drawing too much power through the flakey usb port on the Orange PI and halting the system. I was using a very good power supply and watching the voltage and amps through a USB power meter. I believe that I need a powered USB hub for the receiver to get this project working. The Orange PI is a real finicky little POS. My Raspberry PI is much more resilient and getting Piaware to work on the RPI was as simple as burning the image from Flightaware. I don't have a powered hub so I will have to wait to test my theory. I've attached a photo. The last line shown is where it stopped booting. If the receiver is unplugged it will successfully boot.
Thank you for your fast reply.
Top
 Profile
PostPosted: Sat Nov 19, 2016 1:29 pm
Offline
FlightAware Member
@mcrieman
I have never installed dump1090-fa on my OrangePi, always dump1090-mutability, and it is working for over a year trouble free.
last month I formatted my microSD card and made a fresh install of Armbian, dump1090-mutability, Piaware 3.1 (add-on), and Web Portal, using JP's automated script. It never gave me the problem you mentioned.
I have a spare microSD card. I will format it and install Armbian, dump1090-fa, Piaware add-on and Web Portal using JP's automated Script, and see what happens. What method you used to install the dump1090-fa and Piaware feeder?
Top
 Profile
PostPosted: Sat Nov 19, 2016 1:38 pm
Offline
abcd567 wrote:
@mcrieman
I added the Flightaware repository and used sudo apt-get install for piaware and dump1090-fa. I installed dump1090-fa first, rebooted and then installed Piaware. Can you provide a link to the script you mentioned and I will try everything starting new? Thanks again for your help.
Top
 Profile
PostPosted: Sat Nov 19, 2016 2:41 pm
Offline
FlightAware Member
@mcrieman:
You will need to format your microSD card and make a fresh install of Armbian to use this script.
Here is the link to automated script's thread. The FIRST POST of this thread describes how to install using the script.
Use the code given under "Manual installations..."
ADS-B Receiver Project Setup Scripts
Top
 Profile
Who is online
Users browsing this forum: CommandPost2017, k6rtm, user92891 and 1 guest
Search for:
Jump to:
