I did a small test with my portable ADSB unit.
The nano 2 is absolute not worth the money. MUCH les aircrafts. Les positions.
The test was so obvious that within 5 minutes i throwed the Nano 2 in the trash bin.
So be aware, buy the bigger Nooelec stick. That one works great.
Kind regards, Peter
Thanks for then information and the results of your tests.
Luke
struijs:
Kind regards, Peter
Are you sure you didn’t simply have a loose antenna connection?
You may have not given your SDR (Software Defined Radio) enough time to “settle in”.
I would give it a day or so before making a rush to judgement.
No, sorry. I was also disappointed. Really needed the smaller stick…
Peter
I gave it a week. Same result.
Sorry
Sorry to hear that it didn’t work out for you.
For me? I just warn people not buy this device. Its a waste of money.
Buy the bigger nooelec. Really.
Peter
I realize you are talking about the nano 2 - but
My system is running the nano2+ and it works good for me.
Probably because of 0.5mm tcxo?
(in case you needed a small sdr)
I have two of these tiny SDRs for use with a dual-band Stratux. Small is good when crammed into a little plane, but I found they get VERY hot. Watching a spectrum waterfall shows that they are very susceptible to temperature swings; cooling the PCB with my thumb for a few seconds causes lots of wandering signals. For my use, smaller trumps best reception. I’ll continue to use the larger ones for the home stations.
