Post new topic Reply to topic  [ 355 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15
Author Message
 Post subject: Re: New, inexpensive 1090MHz antenna for sale
PostPosted: Tue Apr 25, 2017 8:44 pm
Offline
alfenheim - FlightAware user avatar
What is the best outdoor or weatherproof cable for this antenna and FlightAware Pro Stick? I did actually buy this cable (https://www.amazon.com/gp/product/B000F ... UTF8&psc=1) but it's significantly dropping receiving signal which was quite disappointing. Any idea or experience with this cable? I both tested with 6.5/26.2ft version.
Any recommendation will be highly appreciated.
Chris
Top
 Profile
PostPosted: Tue Apr 25, 2017 8:56 pm
Offline
mduell - FlightAware user avatar
The problem with that cable is it's reverse (polarity) SMA, there's literally no pin on either end just a gap between the cable and the dongle connector. You need a normal male SMA to male N cable.
Could trying stuffing a little bit of bare wire in there between the holes in the cable and the dongle; should get much better results.
Top
 Profile
PostPosted: Tue Apr 25, 2017 9:33 pm
Online
FlightAware Member
Chris
TEMPORARY WORKAROUND
The SMA-male has center pin. The reverse SMA (RP-SMA) male does not have a center pin, it has a hole. The center wire connection is open because of missing pin. A temporary workaround is to cut a short piece of center wire of coax and insert in hole of RP-SMA male. This piece of wire will act as the missing pin, and connection will be established.
DIFFERENCE BETWEEN SMA AND RP-SMA
Top
 Profile
PostPosted: Tue Apr 25, 2017 10:22 pm
Offline
Wow, now I understand what "reverse" means....thanks very much mduel!
Top
 Profile
PostPosted: Tue Apr 25, 2017 10:24 pm
Offline
Chris
Now I fully understand the difference. Also thanks for providing workaround, let me give a try and will see how it goes!
Top
 Profile
Who is online
Users browsing this forum: ArkLabs, LeifHenrix, mcklai, TomMuc, WillemPennings and 1 guest
Search for:
Jump to:
