Post new topic Reply to topic  [ 355 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15  Next
Author Message
 Post subject: Re: New, inexpensive 1090MHz antenna for sale
PostPosted: Mon Mar 13, 2017 2:55 pm
Offline
FlightAware Staff
ericcarlson - FlightAware user avatar
We apologize for the antennas being temporarily out of stock. As stated earlier in the thread we have them on order but there is an unfortunately complex issue we're working through with the shipper (their mistake, not ours). They are literally "in the mail" so to speak but I do not have an ETA at the moment. As soon as we have updated information from the shipper we will provide updates on when to expect the antennas back in stock on Amazon.
Top
 Profile
PostPosted: Mon Mar 13, 2017 9:18 pm
Offline
steveej - FlightAware user avatar
Thanks for the update. I will keep watching and waiting for them to show up. Hopefully they are worth the wait. I noticed that bundle dealers seem to have them and want a premium for the all in one kits. Amazon and Bay are loaded with them. They can keep them as I like to build my own system anyway and can get at least 2 antennas for what they want for one bundle.
Thanks again. Hopefully in a few days they will be in.
Top
 Profile
PostPosted: Tue Mar 14, 2017 4:47 pm
Offline
djmd808 - FlightAware user avatar
What's should I expect performance wise vs. my homebuilt spider? I kind of want to get one of these for the inherent weather-proof qualities of the N connector and the antenna itself... it'd totally be worth the $45 if I see a bump in aircraft received, even a modest one. I believe I got lucky cutting my antenna, it seems to do GREAT compared to the users around me... but it only has 4 radials and I know many people preach 8 or even more.
Top
 Profile
PostPosted: Tue Mar 14, 2017 6:29 pm
Offline
FlightAware Member
I have done comparison of FA antenna with Cantenna, and found FA antenna performs much better.
My 8 leg Sipder gives nearly same performance as Cantenna, so you can safely take comparison of FA antenna with Cantenna as comparison of FA antenna with Spider.
http://discussions.flightaware.com/post195176.html#p195176
Note:
In above comparison, FA antenna used Filter+ProStic, while Cantenna used generic DVB-T. Later I replaced generic DVB-T (black) by Filter+ProStick, increasing performance of Cantenna by about 30%, but still FA antenna performs better (Message rate of FA antenna about 140% of Cantenna).
Top
 Profile
PostPosted: Sat Mar 18, 2017 8:05 am
Offline
Eric, any update on when the antennas will be available?
Top
 Profile
PostPosted: Sat Mar 18, 2017 2:25 pm
Offline
Ditto :) Some of us may be chomping at the bit!
Top
 Profile
PostPosted: Sat Mar 18, 2017 10:51 pm
Offline
bigredwingfan - FlightAware user avatar
" As soon as we have updated information from the shipper we will provide updates on when to expect the antennas back in stock on Amazon."
Top
 Profile
PostPosted: Sun Mar 19, 2017 8:07 am
Offline
Question wasn't to you. It was to someone in FlightAware.
Top
 Profile
PostPosted: Sun Mar 19, 2017 1:31 pm
Offline
I realize that, but someone in flightaware already answered that question. That was his quote, less than 5 days ago.
So it seems when the info is available, they will tell us.
Top
 Profile
PostPosted: Sun Mar 19, 2017 2:36 pm
Offline
I still was not posted to you. You are not Flightaware.
Top
 Profile
PostPosted: Sun Mar 19, 2017 2:43 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
I can quote the same text from Eric if it makes you happy.
Top
 Profile
PostPosted: Sun Mar 19, 2017 3:08 pm
Offline
Really? Jeeze.. Someone posts for a FA staff member, when the post was specific to the FA staff member and another FA staff member defends that? I know what Eric said 5 days ago. I also realize that things get forgotten and because of projects that are waiting for the FA antenna I need to plan on something THIS WEEK hence the inquiry. If that's the best that you can do then I guess I better plan on something else.
Top
 Profile
PostPosted: Sun Mar 19, 2017 5:11 pm
Offline
FlightAware Staff
If you urgently need an antenna then yes, you should make other plans, because we don't have an ETA yet. When there is more info, Eric will post it. Snapping at people for answering your question won't magically fix the shipping problem.
Top
 Profile
PostPosted: Sun Mar 19, 2017 5:42 pm
Offline
OBJ, I was not snapping. I simply was stating that the posters information was not relevant nor current or even from the person for which it was intended.
I was disappointed in your response though. But, hey.. That's life.
I will make other plans. Sorry I could not invest in more FA equipment.
Thank you for the feedback!
Steve
Top
 Profile
PostPosted: Mon Mar 20, 2017 3:00 pm
Offline
Top
 Profile
PostPosted: Tue Mar 21, 2017 1:18 am
Offline
AlpineMeadows - FlightAware user avatar
In preparation for buying this - was planning on mounting my Pi + Pro stick at the antenna itself with a POE connection to minimize cable losses but I've read that people have had better reception by NOT having the Pi so close to the antenna.
So, should this antenna be used with a length of cable attached vs having the Pi/Pro-stick connected right up to it to get max performance? (need to know what cable length I should get)
TIA
Dave
Top
 Profile
PostPosted: Tue Mar 21, 2017 12:19 pm
Offline
FlightAware Member
jonhawkes2030 - FlightAware user avatar
You can always reduce the gain on the dongle to cater for higher input power.
If reducing the gain doesn't help, then you can also add attenuators to reduce the power level.
I run two devices via POE with LMR400 coax cable and both devices run well. I run another two via POE in my basement.
Keeping the coax short, if available, is a great way to maximise your range.
Top
 Profile
PostPosted: Tue Mar 21, 2017 1:31 pm
Offline
NeoDuder - FlightAware user avatar
TIA
Dave
My antenna and Pi are installed in my loft. The antenna is 3 metres from the Pi. Originally I had a 3m USB lead and had the dongle connected directly to the antenna. Seemed to work ok.
I recently installed an Airband antenna next to the ADS-B antenna, this is connected to another dongle which is plugged directly into the Pi. The airband antenna is connected to the dongle via 3m of low loss coax (WF100). The performance was rather disappointing with a lot of noise and interference. I thought that perhaps the FlightAware dongle being so close was maybe interfering so I changed my setup to mimic the airband setup using another 3m of WF100. Not only did this solve my airband noise issue it also improved my ADS-B reception.
So I now have both antennas connected via 3m of WF100 back to both dongles which are plugged directly into the Pi. Seems to have the best performance for my particular setup. My performance graphs also show around a 4db drop in my noise floor after moving the dongle so it would appear that interference from the dongle affects the antenna if placed too close.
Top
 Profile
PostPosted: Tue Mar 21, 2017 3:40 pm
Offline
FlightAware Member
Putting the dongles in metal cases can help. Ensure that there is a good ground connection at both ends.
I have all of my pro sticks and pro stick pluses in metal cases.
They have a few left at the rtl-sdr website store http://www.rtl-sdr.com/buy-rtl-sdr-dvb-t-dongles/
FA dongles fit without any modification.
I use an RF-choke on 6"/15cm USB extension cables (I use quality USB3.0 cables to have better cabling and shielding, I hope).
The RPI itself can also be put into a metal case to reduce noise(in and out).
If the RPI is in an attic, consider one with a fan to keep it cool in the summer.
Top
 Profile
PostPosted: Tue Mar 21, 2017 8:32 pm
Offline
Thanks guys, just what I needed to know. Was looking for a metal outdoor enclosure and in the end I think I'll attack this from 2 angles. Metal box under the eaves (no need to be waterproof) for the Pi and dongle and a ~10' cable from the dongle to an antenna.
Top
 Profile
PostPosted: Fri Mar 24, 2017 3:53 pm
Offline
FlightAware Staff
Antennas have been delivered (finally) from our supplier. They will start going out to retailers worldwide next week. I expect you will start to see them stocked in the next 1-2 weeks, just depending on how fast each retailer can take in the new inventory. Thanks for your patience.
Top
 Profile
PostPosted: Thu Apr 06, 2017 3:58 am
Offline
HenrikRikardsson - FlightAware user avatar
A friend of mine, that is living in Norway, is trying to buy this very good antenna but it says amazon have changed their shipping so they dont ship outside USA anymore. He also chatted with amazon directly and they said he have to talk to flightaware, amazon and DHT to see if they can do anything about it...
Whats up with this? I hope you can fix it so we can buy this great antenna in Europe as well!
Top
 Profile
PostPosted: Thu Apr 06, 2017 8:53 am
Offline
FlightAware Staff
The antenna is not available directly from FlightAware on Amazon.com anymore. Please try our European retailer ModMyPi.com.
Top
 Profile
PostPosted: Thu Apr 06, 2017 10:30 am
Offline
FlightAware Member
conligwx - FlightAware user avatar
Think they are sold out at the moment, I got the last one:)
Top
 Profile
PostPosted: Thu Apr 06, 2017 10:36 am
Offline
FlightAware Staff
They just received more but they may not have them listed yet. Check back with them soon.
Top
 Profile
Who is online
Users browsing this forum: Ljungskile, MrCaLi, myalias, Yahoo [Bot] and 1 guest
Search for:
Jump to:
