Post new topic Reply to topic  [ 355 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15  Next
Author Message
 Post subject: Re: New, inexpensive 1090MHz antenna for sale
PostPosted: Mon Nov 14, 2016 3:27 pm
Offline
FlightAware Staff
ericcarlson - FlightAware user avatar
ETSI4 wrote:
looks like the 26" FA antenna is sold out in Europe ............................
We must have had a run on them recently; we'll have more on the way shortly.
Top
 Profile
PostPosted: Thu Nov 24, 2016 3:54 am
Offline
TwenteRadar - FlightAware user avatar
The 26" FA antenna is available again in Europe
https://www.amazon.de/1090MHz-ADS-B-Ant ... _i=desktop
Top
 Profile
PostPosted: Mon Jan 09, 2017 11:24 pm
Offline
matthewpilot - FlightAware user avatar
dstreufe wrote:
Has anyone done a comparison of the 26" FA antenna (the only one now available) to this DPD Productions antenna?
http://www.dpdproductions.com/page_vhf_air.html#adsbout
The DPD antenna is significantly more expensive, and claims 9db, but I'm curious if anyone has an real-world figures.
I don't know about the DPD outdoor antenna. I use the DPD indoor blade antenna, and I installed it and the FlightAware 26" antenna in the same spot, and the FA antenna picks up 30-40% fewer position reports than the FA antenna, so I returned the FA antenna.
Top
 Profile
PostPosted: Tue Jan 10, 2017 9:24 am
Offline
FlightAware Member
jonhawkes2030 - FlightAware user avatar
I use the DPD outdoor antenna 1090Mhz Antenna. I liked it so much I have ordered the 978Mhz antenna.
I can't recall doing a direct comparison, however, the DPD antenna does work well.
Top
 Profile
PostPosted: Sun Jan 29, 2017 6:12 am
Offline
SimB - FlightAware user avatar
Hi all,
notice last 10 days significant drop in range and message count. Suspected something wrong with antenna/feeder as we had a hard winter time with strong wind snow and ice. Now weather more less allowing me to check installation. It turned out that FA antenna got some water inside which confirmed my suspicions. Close inspection show that most probably water got inside where fiberglass is glued to metal part in lower end of the antenna. epoxy seems cracked although cracks are very fine and one would not suspect something wrong, but water is water gets his way everywhere.
I got out top of the antenna relatively easy (on the inner surface of the tap there were drops of condensed water) and saw inside that the centerpiece of the antenna is being supported by a plastic foam. I did not disassemble antenna and just wonder how long it will take to get dry. That foam thing is worrying me. I have seen coax feeders with foam insulation and once water got in this feeder needed replacement and never got dry.
Any ideas appreciated. Thanks
Top
 Profile
PostPosted: Wed Feb 01, 2017 7:59 am
Offline
lankosher - FlightAware user avatar
Stock is gone already, will it be re-newed?
Top
 Profile
PostPosted: Wed Feb 01, 2017 9:03 am
Offline
FlightAware Staff
The antenna is available from ModMyPi in the UK: https://www.modmypi.com/raspberry-pi/br ... 6cm--26in/
Top
 Profile
PostPosted: Wed Feb 01, 2017 9:34 am
Offline
Thank you
Top
 Profile
PostPosted: Wed Feb 01, 2017 9:42 am
Offline
FlightAware Member
Skibox - FlightAware user avatar
Hi Eric,
I just received 2 antennas. Please note that the specification available in several places is wrong:
"mounted on a mast that is 2cm to 5cm"
The bracket DOES NOT fit a standard 50mm antenna mast, unfortunately. Very annoying, the bracket is around 45mm ID.
/Marcus
Top
 Profile
PostPosted: Wed Feb 08, 2017 7:24 am
Offline
Regarding how to dry FA antenna I can suggest to remove top of the antenna and put the antenna in the oven set to 60-80 deg C for about several hours. Then check it and repeat procedure again if needed.
As I suspected this plastic foam thing was soaked so drying would take looooong time in room temperature conditions.
The other way is to disassemble the antenna by removing the fiberglass tube, but I have no idea how to do that (unless you cut the tube).
Then it will dry very fast in room conditions, afterwards assemble it back.
If somebody knows how to remove fibreglass tube on non destructive way, please share the knowledge with community.
Top
 Profile
PostPosted: Tue Feb 14, 2017 12:47 pm
Offline
NeoDuder - FlightAware user avatar
Looks like these are out of stock in the UK just now, both on Amazon UK and ModMyPi. Any ideas when they'll be available again?
Top
 Profile
PostPosted: Tue Feb 14, 2017 1:17 pm
Offline
FlightAware Staff
ModMyPi has moved things around in the store. The antenna can be found here: https://www.modmypi.com/electronics/ant ... 6cm--26in/
Or you can just search "FlightAware" on modmypi.com.
Top
 Profile
PostPosted: Wed Feb 15, 2017 2:50 am
Offline
Excellent, ta.
Top
 Profile
PostPosted: Wed Feb 15, 2017 6:16 am
Offline
FlightAware Member
... But still using the wrong specification.
/M
Top
 Profile
PostPosted: Wed Feb 15, 2017 11:25 am
Offline
FlightAware Staff
The mount size measurement has been corrected on modmypi.com. Thanks for pointing out the issue.
Top
 Profile
PostPosted: Wed Mar 01, 2017 5:55 pm
Offline
n4dq4d - FlightAware user avatar
I just got the FA antennna and the Prostick. I had a homemade j-pole and saw around 104nm. Now i am getting almost 180nm. Cant wait to set it up on the roof once the summer comes.
Top
 Profile
PostPosted: Wed Mar 08, 2017 11:43 am
Offline
rkpeck - FlightAware user avatar
Looks like the antenna is out of stock on Amazon at the moment. Any idea of a return to stock date?
https://www.amazon.com/gp/product/B00WZL6WPO/
Roger
Top
 Profile
PostPosted: Wed Mar 08, 2017 10:07 pm
Offline
steveej - FlightAware user avatar
I am in need of one in the USA. Amazon is my preferred. Any idea when they will have them in stock?
Thx,
Steve
Top
 Profile
PostPosted: Fri Mar 10, 2017 4:51 pm
Offline
No reply on the US Supply? You have a run on them here? I noticed there are a lot of bundles but I already bought FA receivers and filters.
Steve
Top
 Profile
PostPosted: Fri Mar 10, 2017 5:49 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
There is another batch on the way but there have been some shipping issues that need to be sorted out before they can head to Amazon. No ETA at the moment.
Top
 Profile
PostPosted: Fri Mar 10, 2017 8:00 pm
Offline
Thanks..
Steve
Top
 Profile
PostPosted: Fri Mar 10, 2017 8:09 pm
Offline
FlightAware Member
Get it from Amazon Canada for Canadian $55 ( = US $40.83)
Top
 Profile
PostPosted: Fri Mar 10, 2017 10:04 pm
Offline
Will they ship to the states?
Top
 Profile
PostPosted: Fri Mar 10, 2017 10:07 pm
Offline
No shipping to the states..
"This item does not ship to your selected location."
Oh well.. Thx
Steve
Top
 Profile
PostPosted: Fri Mar 10, 2017 10:20 pm
Offline
FlightAware Member
mattbna - FlightAware user avatar
Amazon.ca will respond with 'This item doesn't ship to your selected location' when you change the shipping destination country to the United States. Our US Prime memberships also don't work on Amazon.ca.
If shipping logistics to keep Amazon stocked-up on a hot selling item are going to be an issue, I guess I'll continue to keep an extra on-hand at all times. Making plans to travel somewhere to add two more sites and being able to get everything you'll need within a day or two is always nice...until you can't get an antenna. :?
Matt
Top
 Profile
Who is online
Users browsing this forum: cyrosystems, joelwiley and 1 guest
Search for:
Jump to:
