I have fed continuous data now for several months through my Pi 2 B without any problems & have always been syncronized with around 60 local mlat receivers, but for the last week or so my mlat feed has more or less stopped & is constantly showing the following anomaly:
*This feeder is not being used for multilateration because its timing information appears to be unreliable. This can be caused by the site location being incorrect, or because your Pi is running out of free CPU. *
Nothing has changed on the Pi that I am aware of, locations correct & the stats below seem to look ok, any thoughts on what I can try to get it feeding mlat data once again?
Usually most of the time this would be a bad power supply causing the issue that I have seen. Although I have had to replace one Pi that I started getting this message on that just seemed to be going bad. Replaced everything but the Pi and still got the message so I ended up changing the Pi out.
Give following comand in a terminal
pi@raspberrypi ~ $: date
This will display current date & time.
If the time is not correct, you might have to force update it. This is because, by default, ntp will not sync if the difference between the system time and the real-time is greater that 1000 seconds.
To force update, run
pi@raspberrypi ~ $: sudo ntpd -gq
Then restart the ntp server
pi@raspberrypi ~ $: sudo /etc/init.d/ntp restart
After few minutes, check time again
NTP has nothing to do with mlat sync/timing, messing with NTP won’t help, mlat does not use the system clock at all.
If the location is OK and you have spare CPU then the remaining explanation is a hardware problem - the dongles do not tolerate a noisy USB bus well and data will get silently dropped which turns into a mlat timing problem. This can happen with bad mechanical connections, long USB runs, EMI, or just getting unlucky with the particular dongle+Pi combination. For example I have one dongle that works fine and another apparently identical dongle that shows intermittent timing problems.
I never got to find out the cause of the problem but I’ve managed to get the Pi re-feeding MLAT data once again by formatting the sd card & reinstalling a backup of the image that I had made after I first set this Pi up.
Confirmation bias, it was probably the reboot that helped, if you have a system that is unstable over the long term but is sometimes OK in the short term then restarting it will make it work for a little while until the mlat server sees enough instability that it decides to stop using the receiver.
It might be good to add a note to the error message that this has nothing to do with NTP/system clock. It’s clear to the majority, but some keep venturing down the NTP rabbit hole…
