New Mod 3 Rpi, Dump1090-FA & Piaware. Missing “Send Command to Device”. Missing “Auto Update”. Missing Mlat although is operative. Unable to produce these items on this CP. Reboot after stopping Dump1090/FA using terminal (Reinstalling FA). I can’t see why these did not install correctly the first time? Anybody know? Still missing.
That site is identifying itself as neither a package-based install nor a sdcard-based install so the control panel doesn’t know if it safe to send commands to it.
What image did you start with and what steps did you take to install piaware?
The output of piaware-config -showall would be useful to see.
Here is some info: My Ads-b, Adsb, PiAware, (Install PiAware on Your Rpi) Steps 2, 3, 4 (yes, Yes) Copy Paste to instal piaware and dump1090-fa.
pi@raspberrypi:~ $ sudo piaware-config -showall #adept-serverhosts “piaware.flightaware.compiaware.flightaware.com 70.42.6.197 70.42.6.198 70.42.6.191” # using default value #adept-serverport 1200 # using default value
allow-auto-updates yes # value set at /etc/piaware.conf:7
allow-manual-updates yes # value set at /etc/piaware.conf:8 #allow-mlat yes # using default value #beast-baudrate # no value set and no default value #flightaware-password # no value set and no default value #flightaware-user # no value set and no default value #http-proxy-host # no value set and no default value #http-proxy-password # no value set and no default value #http-proxy-port # no value set and no default value #http-proxy-user # no value set and no default value #image-type # no value set and no default value #manage-config no # using default value #mlat-results yes # using default value #mlat-results-format “beast,connect,localhost:30104 beast,listen,30105 ext_basestation,listen,30106” # using default value #priority # no value set and no default value #radarcape-host # no value set and no default value #receiver-host # no value set and no default value #receiver-port 30005 # using default value #receiver-type rtlsdr # using default value #rfkill no # using default value #rtlsdr-device-index 0 # using default value #rtlsdr-gain -10 # using default value #rtlsdr-ppm 0 # using default value #wired-address # no value set and no default value #wired-broadcast # no value set and no default value #wired-gateway # no value set and no default value #wired-nameservers “8.8.8.8 8.8.4.4” # using default value #wired-netmask # no value set and no default value #wired-network yes # using default value #wired-type dhcp # using default value #wireless-address # no value set and no default value #wireless-broadcast # no value set and no default value #wireless-gateway # no value set and no default value #wireless-nameservers “8.8.8.8 8.8.4.4” # using default value #wireless-netmask # no value set and no default value #wireless-network no # using default value #wireless-password # no value set and no default value #wireless-ssid # no value set and no default value #wireless-type dhcp # using default value
pi@raspberrypi:~ $
Hope you can shed some light it?! et al Thank you!
bump: “Is it site 32745 that you’re having trouble with”? It is. Also, I’m running PA 3.1.0 I don’t see what I need let alone to "un comment # it in config?
