Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: methods to show flight info labels directly on dump1090
PostPosted: Tue Jan 17, 2017 3:15 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
Origin & destination airports are not transmitted as part of ADS-B, you'd have to get them from somewhere else.
Top
 Profile
PostPosted: Tue Jan 17, 2017 3:34 pm
Offline
seh2000 - FlightAware user avatar
Yea, I sort of realised this after I had raised the question.
It would have been neat to show, any idea on were I could obtain?
Any thanks for answering!
BR// Steen
Top
 Profile
PostPosted: Tue Jan 17, 2017 3:57 pm
Offline
FlightAware Staff
FlightXML (https://flightaware.com/commercial/flightxml/), flightplan feeds direct from ANSPs (tricky as an individual) or a manually maintained DB of callsign->route (VRS does something like that?)
Top
 Profile
PostPosted: Tue Jan 17, 2017 4:01 pm
Offline
Thanks a lot!
Cheers Steen
Top
 Profile
PostPosted: Thu Mar 09, 2017 3:34 am
Offline
NeoDuder - FlightAware user avatar
Hey Folks,
I have labels on my aircraft, including the zoom code to only show them when zoomed in, thanks to the code provided earlier in this thread...
http://neodude.home.kg/
My issue is that the info on the labels does not update in real time, I need to either zoom out and back in or select a particular aircraft in order for the info to update. Any ideas how to fix this?
Top
 Profile
PostPosted: Thu Mar 09, 2017 3:42 pm
Offline
FlightAware Member
Akissack - FlightAware user avatar
NeoDuder wrote:
Hey Folks,
Should just work see:
https://youtu.be/ZjTRCpiZa5c
email me your files, and i'll see if I can spot what is missing
Allan
Top
 Profile
PostPosted: Thu Mar 09, 2017 4:26 pm
Offline
FlightAware Member
NeoDuder,
thanks for highlighting this, I reviewed the thread and see that there is a bit of code that I didnt post :-(
Another section is needed in
Code:
// Update our marker on the map
PlaneObject.prototype.updateMarker = function(moved) {
within planeobject.js
Now the trouble is that here I have applied further changes, so my code is out of step with the original post. I found a copy of my planeObject.js from Dec 16, but I cant post it as the forum reports 'forbidden - You don't have permission to access /posting.php on this server.' (which seems to be a recurring problem with the forum :-( )
so the best I can offer is that you email me your file and I advise how to fix it
Allan
Top
 Profile
PostPosted: Wed Mar 22, 2017 3:48 pm
Offline
FlightAware Member
Several topics have touched on modifying the map display here. I have posted several images of my modifications and received some interest in others at applying them. To try and allow a self-serve of my modifications I have uploaded them here:
https://github.com/alkissack/Dump1090-OpenLayers3-html
The map and database updates are primarily UK based, so except for aircraft labels (permanent and hover over) there is probably less value outside of the UK. However I offer them here, for you to try out (do please provide feed back and ask questions) first before posting on flightaware.
back up/rename your html directory first – you know it makes sense!
Al
(still some changes to add yet :-)
Top
 Profile
PostPosted: Sat Apr 08, 2017 11:43 am
Offline
gazza221 - FlightAware user avatar
hi everyone, where would this script go in a dump1090 mutability setup ? i can find the line but it is different to the one posted.
cheers
Top
 Profile
PostPosted: Sat Apr 08, 2017 11:59 am
Offline
FlightAware Member
cheers
Gazza, what are you looking to add/achieve?
Top
 Profile
PostPosted: Sat Apr 08, 2017 12:54 pm
Offline
Akissack wrote:
cheers
Hi, I wanted to have the flight info labels to display.
Top
 Profile
Who is online
Users browsing this forum: conexia and 1 guest
Search for:
Jump to:
cron
