Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: location being incorrect
PostPosted: Wed Mar 08, 2017 12:51 pm
Offline
flieger28 - FlightAware user avatar
I have a question regarding entering the location.
I looked the location up on an Website and put it in the "configure location" box on the website.
Is that enough? Or must i enter it also in the dump1090 configuration, in my case dump mutability?
Because i have entered the correct location but the webpage still says location incorrect.
Regards
Eike
Top
 Profile
 Post subject: Re: location being incorrect
PostPosted: Wed Mar 08, 2017 12:54 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
Which webpage?
Top
 Profile
PostPosted: Wed Mar 08, 2017 1:04 pm
Offline
My-ADS-B
Where i can configure the location of the receiver
Code:
Anomaly report for PiAware feeder with a MAC address of XXX:
This feeder is not being used for multilateration because its timing information appears to be unreliable. This can be caused by the site location being incorrect, or because your Pi is running out of free CPU.
Top
 Profile
PostPosted: Wed Mar 08, 2017 1:27 pm
Offline
sloefkesloeber - FlightAware user avatar
if you're feeding via a raspberry, maybe your pi is not set correctly in it's configuration
did you set your location in it ?
in terminal use " sudo raspi-config "to access the configuration part where you can set your location/time region
Top
 Profile
PostPosted: Wed Mar 08, 2017 1:33 pm
Offline
Yeah, i guess that's the problem. Haven't set the location in the pi, only on the Webpage :(
Top
 Profile
PostPosted: Wed Mar 08, 2017 1:44 pm
Offline
FlightAware Staff
Setting the location on the stats page is sufficient. However piaware won't notice the change until it reconnects or about 6 hours has passed. I forced a reconnection so it should be using the new location now.
Top
 Profile
PostPosted: Wed Mar 08, 2017 2:06 pm
Offline
Thank's
Yes it worked
Code:
Feeder Type: PiAware (Debian Package Add-on) 3.3.0
Multilateration (MLAT): Supported / Enabled (synchronized with 102 nearby receivers)
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
