Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Incorrect ADS-B Position Reports
PostPosted: Fri Mar 17, 2017 4:22 pm
Offline
HuffTheWeevil - FlightAware user avatar
Can anyone explain what causes this:
Clearly this UPS aircraft did not land on top of the terminals. It did indeed land on the runway a couple hundred feet to the south of that path. And once on the ground, it continued to report a position that was offset a bit and was a bit "sketchy". The real taxiway he exited on is actually off that image to the right.
This happens to about 0.5-1% of the flights I see.
And it's not MLAT (in my config, the lat/lon in the selected box would be italicized if this were an MLAT position).
Top
 Profile
 Post subject: Re: Incorrect ADS-B Position Reports
PostPosted: Fri Mar 17, 2017 4:59 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
Semi-constant position offsets like this usually mean that the ADS-B position reported is being derived from an inertial system (which drifts over time) not GPS
Top
 Profile
PostPosted: Fri Mar 17, 2017 5:10 pm
Offline
That was my guess. But I don't understand why an ADS-B unit would be set to rely on an IRS over GPS. I thought in today's world IRS was the backup.
Top
 Profile
PostPosted: Sat Mar 18, 2017 12:19 pm
Offline
NeoDuder - FlightAware user avatar
There's probably a switch somewhere to switch between the two but as ADS-B isn't really used much it probably doesn't matter where it is set.
Top
 Profile
Who is online
Users browsing this forum: cancellier, claudep, Google [Bot], myalias and 1 guest
Search for:
Jump to:
