Just did this, it appears to be the same as my screenshot still. Is there something noticeably different in the newer versions than the one in my screenshot?
I dont want to sound like I doubt your knowledge, but that IS exactly what i have running.
This morning I logged in and noticed a notification in the orange bar of the below screenshot (its not visible now) telling me there is a new version 3.5.0. I clicked update and restart, that update seems to have worked as per the screenshot shows…
I click the PiAware Skyview button and it takes me to the screenshot in my Original Post… I dont want to sound argumentative, but everything I have posted thus far is true.
Now it is clear that you upgraded from very old version 2.x.x. This version had a Vanilla like map.
Your browser’s cache is clinging to that map. Clear cache (Alt+Shift+Delete), then hard reload (Ctrl+F5) will purge the old map and most likely you will see SkyView map.
If clearing cache does not solve the problem, try upgrading dump1090-fa.
If all above fails, then go to the SURE and TROUBLE-FREE method: Format microSD Card, download Piaware 3.5.0 image (SD Card), and write the image to your microSD card.
when you upgraded you probably only upgraded PiAware.
when you clicked on send button to upgrade the option “upgrade and restart Pi-Aware” is a drop down box . click on that phrase and you will be able to select “upgrade piaware and dump1090” then click send and it should sort you out.
I tried the clear cache and reload page, this didn’t work, I tried a different web browser, this still didn’t work, then I saw theresjam post, and that was the problem, it seems when I updated I didn’t realise there was a second option to update dump1090, so I just now selected that option, then restarted the PI and it has come up with the newer looking viewer.
Thanks heaps guys.
Just for my own knowledge, how can I tell what version of 1090 I am running? Just so I know for future to tell if its the latest version?
You missed what I have written after “clearing cache” step. Later theresjam singled it out and wrote it in an eleborate way, helping you catch the point.
How to Find Version Number:
I don’t have anything running dump1090 at the minute however.
You could try this from the command prompt on the Pi
./dump1090 --help
might work, i’m not sure if the flight aware dump1090 is named the same. type in dump1090 at the command prompt and hit tab if it isn’t just dump1090 that should autocomplete.
