I found some weird phrasing in your pro-stick testing radioforeveryone.com/p/more- … tests.html
After publishing the Pro Stick Plus review, I 've seen comments that the Plus can overload on the FA antenna, so felt the need to conduct further side-by-side comparisons.
If you think the Plus overloads on a the FlightAware antenna, just turn down gain in software step by step and monitor results.
It is the dongle(Pro-stick) that can be overloaded, not the antenna.
I do not agree that it is just a matter of turning down gain. The down-side with the PsP is that the LNA is in front of the SAW filter, and strong RF interference will saturate the LNA. The gain setting does not affect the LNA, only the usual SDR-stick RF amp which is after the SAW. The gain setting has very little, if any, effect when this happens. we see this quite often, mainly due to proximity to the GSM900 BTSes which the external FA-filter also does not block.
But it says (as in the text you quoted) “overload on the antenna”, not “overload the antenna”.
At least I read it as overload when connected to the FA antenna, which is correct.
I use a cavity filter that even helps with Primary radar on 1030Mhz(I live near several major airports, all of which have radar and have a dozen cell towers within a few blocks).
Even with the Prostick, i got 2 aircraft(at at time) without a filter and 200 with one.
The FA filter even helps out on UAT 978. I am waiting on some custom cavity filters for 978Mhz.
I use torroids on all USB (Short 6" USB 3.0 cables to cater for the tight fit on the USB connectors) and Power connectors. I have all my RPIs and dongles in Metal cases. I may try to better cool the dongles as was suggested on the website.
I did not imply that an antenna can overload. amplified radios will overload with a high gain antenna.
@Skibox
“The gain setting does not affect the LNA, only the usual SDR-stick RF amp which is after the SAW”
This is true, however, by lowering gain in software you also lower the noise floor of the stick preamp, thereby lowering overall system noise floor. Check out the noise profile of a v.2, upon which the Pro Sticks are remotely based.
I’m running tests at the moment, two preamps and a Pro Stick Plus actually work . A cavity filter will be also reviewed in the near future, don’t know when, because tests take time.
