I think I am not alone in experiencing a slow, gradual decline in the numbers of Aircraft & Messages that I receive. There was talk of a chip in the Prostick that begins to fail as it warms up.
Outdoor Collinear at 50M, Prostick & Filter 3.1.0
Does anyone have a solution or any helpful suggestions please?
1.1s have the version number printed on the case. (I can’t remember if 1.0s do or not)
But I wouldn’t expect the TCXO to really have much of an effect either way here.
Have you checked your connections / antenna for moisture or corrosion?
As obj said, have you checked your connections / antenna for moisture or corrosion. Every time I’ve had this issue, moisture/corrosion was the problem.
The version number is printed on the outside of the case, not on the circuit board, so you shouldn’t need to open it.
If it says 1.0 and you ordered it after the first month of availability then it possibly has TCXO (manufacturing was supposed to have used cases that say 1.1 for the TCXO units, but confusion occurred). All cases that say 1.1 should definitely have TCXO.
