Hello everybody,
I’ve been working on my setup over the past couple weeks and I’m frustrated to the point where I’m close to tossing it all into a bin. I’m pretty much stuck.
From the beginning…
One of my experiments after I received my first rtl-sdr-dongles was to setup one of my old Raspberry Pis (in fact the oldest one I own… an MKI model from the very first batch with just 256MB memory) out on the balcony to track aircraft. I did not really care too much about it back then, I stuck two pieces of wire on a wine cork to form my first dipole, and it was tracking away. I was actually running on a battery pack for the first days, but then upgraded to POE. I put a bucket over it at first to protect it from the weather.
Some time later I started optimizing. I read about the PRO stick and ordered one. Tinkered a little with the gain, but then filters became available a week later or so, and I got one of those, too.
I ordered a nice weatherproof housing and mounted everything inside (and switched to a different Raspberry in the process, since the original one did not offer any mounting holes).
Then I wanted to go full scale. I decided to put up a nice antenna. I made a 16-segment coaxial collinear antenna out of RG58 cable. I posted about that in another thread and ExCalbr informed me that this might actually not yield the best results. So i started experimenting with different lengths and found that he was right and 8 segments gives me the best results. Or, that’s what I thought.
Up until yesterday, I didn’t bother to slip the antenna into its designated PVC pipe. To speed up the testing, I just used e-tape and stuck it kind of loosely to the outside of the pipe. With bad weather coming up, I decided to change that yesterday, and… well, the result is devastating…
The easiest conclusion here might be that the pipe is made from the wrong material… Well yeah, I’m not really sure it’s actually PVC. I got it at the local hardware store and wasn’t really paying attention. It is some kind of plastic… But here’s what makes me think that it’s not the pipe: When I took the original 16-segment out and stuck it to the outside, I did not see any kind of impact whatsoever.
The thing I’m more suspicious about is actually noise:
As you can see, the noise usually dropped down to around -30dB at night before the operation. Last night, the best figure seems to be somewhere around -23dB.
I do have two suspicions about what might be causing this… Number one is the network cable, that was very close to the pipe (and not very close to the loosely hanging feed cable during my various experiments… The antenna itself starts above the point where the network cable passes the pipe). I have removed the cable now and put it at some distance to the antenna and feed line, but could not really see an improvement.
Number two is the metal frame that the pipe is attached to. Since the CoCo is a symmetric antenna, the shielding of the feed line might be doing some strange interactions (capacitive coupling or similar) within the 40cm it is now running strictly parallel to the metal part of my balcony. And I don’t really have many other things to attach it too. I have thought about drilling a hole sideways into the pipe and put the feed line through there just to get it away from any metal parts, but I don’t know if that would work…
So far for receiver number one. In the meatime, I also started experimenting with a second receiver, that has very much potential, but will be entailed by different problems.
That second receiver’s position is up in the attic, which is one floor higher than my primary one. It’s positioned inside, but since the roof’s insulation seems to be free of any metals, it has very nice potential reception. To confirm that, I ordered a second PRO stick + filter, and did some experiments. I have managed to establish a (very weak) wifi link (that gives me 10-15% loss of mlat messages) and am currently running off a battery pack. I equipped the receiver with the remainder of my balcony antenna, so it’s running a 8-segment CoCo as well.
This screenshot shows VRS range plots after less than 24h of total receiving time (not consecutive, the battery just gives about 14h). Rings are 50NM:
Hell yeah. 3 indents from the west up to the north due to 3 houses standing in the way. some range loss in the southwest due to the building wall. And one major indent to the northeast that is caused due to a huge metal tank (I suppose it’s the expansion tank of the heating system, so it’s very likely filled with water, too) and the elevator service room. That latter indent partially blocks the view of the local airport, so the receiver currently has a very nice range distribution. Some of these might be overcome by a better placement of the antenna.
But here’s the problem: I don’t have any power up there to run the receiver 24/7. And I really can’t get used to the idea of having to switch the battery twice a day.
So here I am, having set up two receiveres, and happy with none of them. If you happened to have read all of what I have written I already owe you a big thanks, and if you have any ideas to help me out, I’d be very, very happy.
Cheers!
