Hey Gang,
I’ve been running piaware v2 on a Pi 2 for nearly a year now, and it’s been flawless. Last month I changed to piaware v3.1, and it’s been constantly dropping out after random time periods. It’s just a straight-up base image with no modifications other than a static IP address. After running for some number of hours, suddenly my msg/min from dump1090 will drop from 100+ down to 0-10. Sometimes it recovers on its own after the system notices no new messages and tries to restart dump1090 automatically, other times it won’t recover and I have to issue “sudo shutdown -r” for a reboot, after which it’s fine again. Check out the piaware log below; the problem is show starting here around 16:16.
I’m also running modesmixer2 on a separate windows box to receive positions from piaware. When the problem happens, I can see there that the connection is being dropped repeatedly (see end of post).
I’ve re-flashed the SD card a couple times, but am about to give up and go back to v2.15. Also, just another “feature” to mention: I’ve noticed that changing the password on the “pi” account doesn’t stick. It works for a while then reverts back to “flightaware”. Odd.
piaware.log
Oct 12 15:49:18 piaware piaware[435]: mlat-client(13566): Results: 20.4 positions/minute
Oct 12 15:49:18 piaware piaware[435]: mlat-client(13566): Aircraft: 5 of 6 Mode S, 3 of 5 ADS-B used
Oct 12 15:51:33 piaware piaware[435]: 131404 msgs recv’d from dump1090-fa (132 in last 5m); 131319 msgs sent to FlightAw
Oct 12 15:56:33 piaware piaware[435]: 131557 msgs recv’d from dump1090-fa (153 in last 5m); 131472 msgs sent to FlightAw
Oct 12 16:01:33 piaware piaware[435]: 131699 msgs recv’d from dump1090-fa (142 in last 5m); 131614 msgs sent to FlightAw
Oct 12 16:04:18 piaware piaware[435]: mlat-client(13566): Receiver status: connected
Oct 12 16:04:18 piaware piaware[435]: mlat-client(13566): Server status: clock unstable
Oct 12 16:04:18 piaware piaware[435]: mlat-client(13566): Receiver: 37.0 msg/s received 25.7 msg/s processed (69
Oct 12 16:04:18 piaware piaware[435]: mlat-client(13566): Server: 0.1 kB/s from server 0.0kB/s TCP to server
4kB/s UDP to server
Oct 12 16:04:18 piaware piaware[435]: mlat-client(13566): Results: 26.9 positions/minute
Oct 12 16:04:18 piaware piaware[435]: mlat-client(13566): Aircraft: 8 of 10 Mode S, 2 of 2 ADS-B used
Oct 12 16:06:33 piaware piaware[435]: 131811 msgs recv’d from dump1090-fa (112 in last 5m); 131726 msgs sent to FlightAw
Oct 12 16:11:33 piaware piaware[435]: 131952 msgs recv’d from dump1090-fa (141 in last 5m); 131867 msgs sent to FlightAw
Oct 12 16:16:33 piaware piaware[435]: 132016 msgs recv’d from dump1090-fa (64 in last 5m); 131931 msgs sent to FlightAwa
Oct 12 16:19:18 piaware piaware[435]: mlat-client(13566): Receiver status: connected
Oct 12 16:19:18 piaware piaware[435]: mlat-client(13566): Server status: not synchronized with any nearby receivers
Oct 12 16:19:18 piaware piaware[435]: mlat-client(13566): Receiver: 17.5 msg/s received 12.0 msg/s processed (69
Oct 12 16:19:18 piaware piaware[435]: mlat-client(13566): Server: 0.0 kB/s from server 0.0kB/s TCP to server
2kB/s UDP to server
Oct 12 16:19:18 piaware piaware[435]: mlat-client(13566): Results: 8.7 positions/minute
Oct 12 16:19:18 piaware piaware[435]: mlat-client(13566): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
Oct 12 16:21:33 piaware piaware[435]: 132017 msgs recv’d from dump1090-fa (1 in last 5m); 131932 msgs sent to FlightAwar
Oct 12 16:26:33 piaware piaware[435]: 132017 msgs recv’d from dump1090-fa (0 in last 5m); 131932 msgs sent to FlightAwar
Oct 12 16:31:33 piaware piaware[435]: 132017 msgs recv’d from dump1090-fa (0 in last 5m); 131932 msgs sent to FlightAwar
Oct 12 16:34:19 piaware piaware[435]: mlat-client(13566): Receiver status: connected
Oct 12 16:34:19 piaware piaware[435]: mlat-client(13566): Server status: not synchronized with any nearby receivers
Oct 12 16:34:19 piaware piaware[435]: mlat-client(13566): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%
Oct 12 16:34:19 piaware piaware[435]: mlat-client(13566): Server: 0.0 kB/s from server 0.0kB/s TCP to server
0kB/s UDP to server
Oct 12 16:34:19 piaware piaware[435]: mlat-client(13566): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
Oct 12 16:36:33 piaware piaware[435]: 132018 msgs recv’d from dump1090-fa (1 in last 5m); 131933 msgs sent to FlightAwar
Oct 12 16:41:33 piaware piaware[435]: 132024 msgs recv’d from dump1090-fa (6 in last 5m); 131939 msgs sent to FlightAwar
Oct 12 16:46:33 piaware piaware[435]: 132031 msgs recv’d from dump1090-fa (7 in last 5m); 131946 msgs sent to FlightAwar
Oct 12 16:49:19 piaware piaware[435]: mlat-client(13566): Receiver status: connected
Oct 12 16:49:19 piaware piaware[435]: mlat-client(13566): Server status: not synchronized with any nearby receivers
Oct 12 16:49:19 piaware piaware[435]: mlat-client(13566): Receiver: 0.0 msg/s received 0.0 msg/s processed (0%
Oct 12 16:49:19 piaware piaware[435]: mlat-client(13566): Server: 0.0 kB/s from server 0.0kB/s TCP to server
0kB/s UDP to server
Oct 12 16:49:19 piaware piaware[435]: mlat-client(13566): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
Oct 12 16:49:19 piaware piaware[435]: mlat-client(13566): Out-of-order timestamps: 2
modesmixer2
2016-10-13 12:19:13.763 INFO inConnect(10.1.110.30:30105) connecting 10.1.110.30:30105
2016-10-13 12:19:13.772 INFO inConnect(10.1.110.30:30105) connected
2016-10-13 12:21:14.923 INFO inConnect(10.1.110.30:30105) BEAST data stream detected
2016-10-13 15:21:27.867 INFO inConnect(10.1.110.30:30105) disconnected
2016-10-13 15:21:27.870 INFO inConnect(10.1.110.30:30105) reconnect in 10 seconds
2016-10-13 15:21:28.636 INFO inConnect(10.1.110.30:30005) disconnected
2016-10-13 15:21:28.639 INFO inConnect(10.1.110.30:30005) reconnect in 10 seconds
2016-10-13 15:21:37.874 INFO inConnect(10.1.110.30:30105) connecting 10.1.110.30:30105
2016-10-13 15:21:38.644 INFO inConnect(10.1.110.30:30005) connecting 10.1.110.30:30005
2016-10-13 15:21:47.874 ERROR inConnect(10.1.110.30:30105) host 10.1.110.30:30105 connect timeout
2016-10-13 15:21:47.879 INFO inConnect(10.1.110.30:30105) reconnect in 11 seconds
2016-10-13 15:21:48.644 ERROR inConnect(10.1.110.30:30005) host 10.1.110.30:30005 connect timeout
2016-10-13 15:21:48.649 INFO inConnect(10.1.110.30:30005) reconnect in 21 seconds
2016-10-13 15:21:58.884 INFO inConnect(10.1.110.30:30105) connecting 10.1.110.30:30105
2016-10-13 15:22:02.389 ERROR inConnect(10.1.110.30:30105) connect host 10.1.110.30:30105 error No connection could
be made because the target machine actively refused it
2016-10-13 15:22:02.398 INFO inConnect(10.1.110.30:30105) reconnect in 27 seconds
2016-10-13 15:22:09.653 INFO inConnect(10.1.110.30:30005) connecting 10.1.110.30:30005
2016-10-13 15:22:09.658 INFO inConnect(10.1.110.30:30005) connected
2016-10-13 15:22:10.821 INFO inConnect(10.1.110.30:30005) BEAST data stream detected
2016-10-13 15:22:16.953 INFO Coverage area was determined
2016-10-13 15:22:29.403 INFO inConnect(10.1.110.30:30105) connecting 10.1.110.30:30105
2016-10-13 15:22:30.412 ERROR inConnect(10.1.110.30:30105) connect host 10.1.110.30:30105 error No connection could
2016-10-13 15:22:30.421 INFO inConnect(10.1.110.30:30105) reconnect in 51 seconds
2016-10-13 15:23:21.426 INFO inConnect(10.1.110.30:30105) connecting 10.1.110.30:30105
2016-10-13 15:23:21.429 INFO inConnect(10.1.110.30:30105) connected
2016-10-13 15:25:22.041 INFO inConnect(10.1.110.30:30105) BEAST data stream detected
2016-10-13 15:29:23.309 INFO inConnect(10.1.110.30:30105) disconnected
2016-10-13 15:29:23.313 INFO inConnect(10.1.110.30:30105) reconnect in 10 seconds
2016-10-13 15:29:33.318 INFO inConnect(10.1.110.30:30105) connecting 10.1.110.30:30105
2016-10-13 15:29:34.325 ERROR inConnect(10.1.110.30:30105) connect host 10.1.110.30:30105 error No connection could
2016-10-13 15:29:34.332 INFO inConnect(10.1.110.30:30105) reconnect in 21 seconds
2016-10-13 15:29:55.337 INFO inConnect(10.1.110.30:30105) connecting 10.1.110.30:30105
2016-10-13 15:29:56.343 ERROR inConnect(10.1.110.30:30105) connect host 10.1.110.30:30105 error No connection could
2016-10-13 15:29:56.351 INFO inConnect(10.1.110.30:30105) reconnect in 36 seconds
