Hello,
I have a CuBoxi from Solid-Run.com that can run Android. The device has Wi-Fi, Ethernet port and USB ports.
Does anybody tried to configure FlightFeeder with this device before? Any tips would be great if you have them.
Thank you…
Hello,
Thank you…
You may be better off seeing if debian armhf will run on that rather than android; you should be able to use the raspbian piaware packages in theory.
Thanks for the reply. I will see if I can install the Debian. I did download FlightFeeder for Android and it is working. I have about 5 aircraft showing up on it. I believe a better antenna would have more aircraft show up.
