Feeding Planeplotter using PiAware 3.0.4
Anyone else feeding Planeplotter from Piaware 3.0.4
When I used 2.1.5 I build it using as Raspian image then set each feeder up, but now I have used the 3.0.4 Image i’m a bit unsure what to do.
THanks
Jason
Yes. It works exactly the same (I had to make zero change for Planeplotter). You should not have to do anything if you use standard ports and the IP address is the same.
I just changed my IP address one number down: 192.168.1.123:30005, Feeds fine. Also feeding SBS Plotter on port 30003. No issues…
