The latest dump1090-fa appears to work very well but has one annoyance that could be really great to fix…
Every time the dump1090-fa starts it creates the /var/run/dump1090-fa directory and removes it on shutdown.
If the directory is already there dump1090-fa just fails to start
dump1090-mutability does not recreate the directory on startup and does not remove it on exit.
I would like to permanently keep /var/run/dump1090-fa directory as I have some scripts that get confused when the directory is not there.
Do you mind to explain the reason why FA version does it differently then mutability?
Is there any way to disable the startup check and directory cleanup on exit?
Can you add this option to the next release please?
Really appreciate your help!
