Dump 1090-fa on orange pi zero connection refused
hello, i’ve succesfully build and configured a ads-b reciever with a simple rtls 2832u usb reciever and an orange pi zero pc. Piaware is working good, but when i try to enter the webpage of dump 1090 i get a “connection refused” message. Why? Maybe i need to setup other things? :confused: Because the tracking is working pretty well( i see that on flightaware page i get a lot of aircraft tracked), but i want to see tracked aircrafts. thanks in advance for the support. :slight_smile:
If you have installed dump1090-fa:
http :///dump1090-fa/
If you have installed dump1090-mutability:
http :///dump1090/gmap.html
no results… conly connection refused
Perhaps lighttpd didn’t get set up correctly? Do you have a link to a dump1090-fa configuration file in /etc/lighttpd/conf-enabled? Does /usr/share/dump1090-fa/html have an index.html and a bunch of .js files? This is where the lighttpd should be pointing the dump1090-fa link. If that looks good you can try to open it on a browser running on the orange pi going to 127.0.0.1/dump1090-fa and find out if it’s being blocked by your router or something.
Also try :80 and :8080
Are you sure you are using correct ?. Your correct local ip is shown on your FA stats page
