Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: Displaying 2 sites on 1 map
PostPosted: Thu Mar 16, 2017 3:54 am
Offline
FlightAware Member
MikeMathee - FlightAware user avatar
I have two sites running dump1090-fa and PiAware.
Both sites are feeding to FlightAware.
I'm planing on moving the one site to a different location about 100km's away to cover that area.
Would it be possible to view to aircraft of both sites on one map?
How could this be done and what would be needed to achieve this?
Top
 Profile
 Post subject: Re: Displaying 2 sites on 1 map
PostPosted: Thu Mar 16, 2017 7:32 am
Offline
FlightAware Member
LCOVA76 - FlightAware user avatar
Install Virtual Radar Server and configure both radars on it...
You can then see both radars on the same map.
Top
 Profile
PostPosted: Thu Mar 16, 2017 7:44 am
Offline
FlightAware Member
I haven't looked at Virtual Radar Server yet, will it run on the Raspberry Pi?
Does it offer the same features as the dump1090-fa map?
Top
 Profile
PostPosted: Thu Mar 16, 2017 8:02 am
Offline
FlightAware Member
MikeMathee wrote:
I haven't looked at Virtual Radar Server yet, will VRS run on the Raspberry Pi?
VRS runs on Windows computer, and gets data from Pi through LAN or through Internet.
Redirecting Piaware 3.3.0 to remote Virtual Radar Server VRS
Top
 Profile
PostPosted: Thu Mar 16, 2017 8:21 am
Offline
FlightAware Member
Thank you, I'll have a look at that link.
Are there any solutions that runs on the Raspberry Pi?
I would prefer not to run a Windows PC constantly.
Top
 Profile
PostPosted: Thu Mar 16, 2017 9:00 am
Offline
FlightAware Staff
obj - FlightAware user avatar
dump1090 will do it, but you will need to sort out the glue yourself: run a 3rd dump1090 instance in --net-only mode and use socat/netcat to feed data from port 30005 on each receiver to the 3rd instance's port 30004 (or whatever is configured via --net-bi-port)
nb: do not feed the other receiver's data into an existing dump1090 that piaware is reading data from, it will break mlat.
Top
 Profile
PostPosted: Thu Mar 16, 2017 9:48 am
Offline
FlightAware Member
Thank you obj,
I'll look into your solution.
Top
 Profile
PostPosted: Thu Mar 16, 2017 9:26 pm
Offline
idoleo2001 - FlightAware user avatar
Anybody can explain step by step the process?
I have now 5 equipments in different place, in two countries and it will be nice merge all data.
idoleo2001
Top
 Profile
PostPosted: Fri Mar 17, 2017 6:08 pm
Offline
jluebbe - FlightAware user avatar
Hi,
There are basically two ways to accomplish that:
Collect data from sources and feed it to the dump1090 instance with the net-only option. Here, you need to ensure that this combined data is not fed anywhere(flightaware and others).
Or you do a hack of the web interface, where you create a combined aircraft.JSON with data from all your sources. I did something similar, but added data from the opensky API to my dump1090 web interface.
Top
 Profile
PostPosted: Fri Mar 17, 2017 9:06 pm
Offline
FlightAware Member
N456TS - FlightAware user avatar
--> Aggregation of dump1090-mutability outputs
Top
 Profile
Who is online
Users browsing this forum: cancellier, claudep, Ljungskile, myalias, Yahoo [Bot] and 1 guest
Search for:
Jump to:
