I am a new user. I have a Raspberry Pi and running OS X 10.11.4. The Raspberry is conected to my router. The problem is FR24FEEDOSX only feeds when the computer is running. How can I feed 24/7 directly through with out running FR24FEEDOSX ?
Would appreaciate any help I can get.
If you can handle a few Linux commands you will be fine. Try it on a second sd card so you can easily revert to your current setup.
The scripts were put together by someone that wanted to be able to quickly and simply build piawares.
It takes 15-20 minutes,gives you a much better, if DEV, version of dump1090 and allows you to feed your choice of sites.
He has had “ready to use SD images” available for a month or so. The hardest part for me was unzipping them(I had to transfer the image to an RPI, load 7-zip, unzip then transfer it back to the PC to burn to the SD card. There could be a version that works on PCs).
