Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
 Post subject: Re: Changes to how new PiAware feeders are identified
PostPosted: Tue May 02, 2017 10:46 am
Offline
FlightAware Member
jimcander - FlightAware user avatar
Hey Oliver -
Any word on converting MAC based installations to ID based installations?
Jim
Top
 Profile
PostPosted: Wed May 17, 2017 1:18 pm
Offline
Ljungskile - FlightAware user avatar
obj wrote:
If you have an existing site this does not affect you - existing sites will continue to be identified by MAC address at the moment.
I have changed hardware on my site, I would like to keep the old site ID, Im using the same image (different SD-card, but I have made sure it has the old sites ID now)
Could you please remove site 43294 and make sure that site 19882 identifies by ID instead of MAC?
Edit:
I didnt want to loose my "longest streak" (from the first day I started with this) on 19882, so I did as GeorgLichtblau and many others, i spoofed the MAC from the old Pi. But I still hope to be able to identify 19882 by ID instead of MAC in the future. It would make it easier when changing out hardware.
Top
 Profile
PostPosted: Wed May 17, 2017 2:41 pm
Offline
GeorgLichtblau - FlightAware user avatar
I've changed hardware at one of my receivers (registered before the feeder-id) today...
As I wanted to keep my old stats I changed the mac-address to the old one and fiddling around for two hours with just creating new feeder-ids :)
So the quick and very, very dirty hack to get it to work by just using the mac-address was:
rm /var/cache/piaware/feeder_id
touch /var/cache/piaware/feeder_id
chmod 000 /var/cache/piaware/feeder_id
As said... very, very dirty.. but it works :)
Top
 Profile
PostPosted: Wed May 17, 2017 6:24 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
That will break in the near future.
Top
 Profile
PostPosted: Wed May 17, 2017 8:23 pm
Online
FlightAware Member
The Piaware of a new Pi with new image obtains a new feeder-id immediately at FIRST BOOT, if:
(1) Mac address spoof was not done BEFORE FIRST BOOT
OR
(2) Mac address spoof was done, but it did not work due to line break in file cmdline.txt
The trouble free way to spoof mac address is to do it BEFORE FIRST BOOT of the newly written image, and to ensure there is no line break in file cmdline.txt.
After writing the image, and while the microSD card is still in card reader of Laptop/Desktop, click on the drive letter of microSD card. This will open the /boot folder (the only folder visible in laptop/desktop). Then open the file cmdline.txt using Wordpad (do not use Notepad, as it creates a line break in the file when it is saved, and because of line break, the mac spoof does not work).
This file has only one line. At the end of this line, add (without line break) following and save file.
smsc95xx.macaddr=xx:xx:xx:xx:xx:xx
(replace xx:xx:xx:xx:xx:xx by mac address of old Pi)
Now take out card from laptop/desktop, plugin into Pi and do the FIRST BOOT.
If a line break was introduced, then even if you edit file cmdline.txt in nano editor in SSH console and remove the line break, Piaware by that time has already obtained a new 128 bit site identifier, and you will be faced with problem of getting rid of it.
To enable SSH, you will also need to create a new file SSH in /boot folder BEFORE FIRST BOOT, while the microSD card is still in card reader of laptop/desktop.
Top
 Profile
PostPosted: Sat May 27, 2017 4:16 pm
Offline
alleyoopie - FlightAware user avatar
A couple of weeks ago, I made a complete set (Pi/dongle/antenna) as a test for a friend so initially I registered it as a second feeder under my own account.
My friend has now decided to keep the set and continue as an independant feeder, how do I proceed to convert my second feeder into an independant one? (it's already the version with a unique identifier)
Top
 Profile
PostPosted: Sat May 27, 2017 4:36 pm
Offline
FlightAware Staff
If you stop piaware, remove /var/cache/piaware/feeder_id, and restart piaware, then it will create a new site when it logs in and your friend can claim that site for themselves.
Top
 Profile
PostPosted: Sun May 28, 2017 5:58 am
Offline
Unfortunately the same feeder_id is created the moment I restart piaware, this is what I do:
sudo systemctl stop piaware
piaware-status (to check that piaware has been stopped)
sudo rm feeder_id (when in the /var/cache folder)
ls (to check the file has gone)
piaware-status (to check that piaware has been started again)
I also tried to reboot the pi (sudo reboot) just after having deleted the feeder_id but alas, to no avail...
Top
 Profile
PostPosted: Sun May 28, 2017 9:46 am
Offline
FlightAware Staff
Wrong directory.
edit: I looked at the logs and your piaware is providing the same feeder ID as configured data. That means either you configured it explicitly in piaware-config.txt or you've done something to make /var/cache/piaware/feeder_id unwriteable by piaware (piaware treats both cases the same - as a configured feeder ID that it can't update)
Top
 Profile
PostPosted: Sun May 28, 2017 10:57 am
Offline
Your hint does ring a bell. Originally I configured the Pi at my home but at my friends place it kept rebooting because the AC adapter that he used couldn't deliver enough current. Once this was solved I had to reimage the Pi due to a crashed µSD-card but this created a third account which I solved by including the original ID in the config file. I guess the problem will be solved by removing this entry and going through the same procedure as mentioned above.
Top
 Profile
PostPosted: Tue May 30, 2017 12:00 am
Offline
GGITech - FlightAware user avatar
Can you change MAC: b8:27:eb:e9:b1:79 to the newer Unique Identifier?
Top
 Profile
PostPosted: Thu Jun 08, 2017 6:55 am
Offline
sbontempo - FlightAware user avatar
Hi all, I performed an update on my piaware last night via the site and then rebooted. After the reboot, Piaware came back up with a completely new ID and a new nearest airport an hour and a half away from me. I need to get it back to the original ID. Is there a procedure online to do this?
Thanks!
Top
 Profile
PostPosted: Thu Jun 08, 2017 7:57 am
Offline
sharkbit - FlightAware user avatar
Looks like this will be a bigger issue as people update their Pi's. I updated mine last night as well.
I think the Big Fix would be that Flight Aware generate the "Unique Identifier" for all Sites that don't have one now. That would allow us to move our updated pi-aware back to the old site.
Top
 Profile
PostPosted: Thu Jun 08, 2017 9:19 am
Offline
FlightAware Staff
That is the plan.
Top
 Profile
PostPosted: Thu Jun 08, 2017 9:54 am
Online
FlightAware Member
An old station is identified by mac address, and there is no 128 bit id (long id xxxxxxx-xxxx-xxxx-xxxxxxxxxxxx) mentioned on the FA stats page.
However I noted that a 128 bit feeder id is assigned and saved in RPi
pi@piaware:~$ cat /var/cache/piaware/feeder_id
895008aa-1434-4084-4c91-f3dc0abe0e14
I checked other two places
pi@piaware:~$ cat /boot/piaware-config.txt
#no feeder-id found
pi@piaware:~$ sudo piaware-config -show feeder-id
#no feeder-id displayed
I deleted the cache file, and rebooted
pi@piaware:~$ sudo rm /var/cache/piaware/feeder_id
pi@piaware:~$ sudo reboot
Now checked, found a new feeder id is assigned
837dde67-e5f8-4bbe-8c1f-de874b993f64
I repeted "delete cache file and reboot", yet another new id was assigned.
The station number did not change by this "feeder-id deleting/new feeder-id creation" game.
What is the purpose of this feeder-id, and why a new one is assigned on deleting current feeder-id?
I also found that old sites are still behaving as before to the mac address spoof. When I spoofed mac address, a new site # was alloted, and the pi started feeding it. When I removed the mac address spoof, the pi started feeding the old site.
Top
 Profile
PostPosted: Thu Jun 08, 2017 10:38 am
Offline
FlightAware Staff
Feeder ids are allocated even when the site is using Mac address as the primary identifier so that we can move the existing site to use feeder id without losing the existing site association when the time comes
Top
 Profile
PostPosted: Tue Jun 20, 2017 11:38 am
Offline
FlightAware Member
bidgee - FlightAware user avatar
Regret doing an update! My Mac address changed (thought spoofing would work but someone didn't check the forum :oops: ) and now I have two feeds. :cry:
http://flightaware.com/adsb/stats/user/ ... stats-6482 is the one I want to continue to use and http://flightaware.com/adsb/stats/user/ ... tats-57171 is the one I want gone!
Top
 Profile
PostPosted: Tue Jun 20, 2017 2:14 pm
Offline
hans1804 - FlightAware user avatar
I upgraded the hardware of my site and can't configure is to my old feeder-id. It's an older site recognized by it's Mac adres. I did find a feeder ID in the old piaware logfiles and tried to configure that. Didn't work.
Is there anyway I can get my old feeder stats back or is it really history, which would be a bit disappointing.
I added a test-site but this whole configuration exercise left me with 4 feeder sites.
Top
 Profile
PostPosted: Tue Jun 20, 2017 4:13 pm
Online
FlightAware Member
Please see thread Bake a Pi
If you have installed Piaware 3.5.0 image (SD card), go to OPTION-1, item "(5) (c) If you are replacing old Pi by a new one"
If you have installed Raspbian + Piaware 3.5.0 (package install), go to OPTION-2, item "(9) If you are replacing old Pi by a new one".
After steps mentioned above, you will have to delete file feeder_id before reboot
sudo reboot
Top
 Profile
PostPosted: Tue Jun 20, 2017 4:48 pm
Offline
I had almost the same situation here. Spoofing the MAC-Address but new feeder was generated.
The very, very dirty way to solve this is described here.... post207088.html#p207088
But please just read also the following post from obj... Anyway my new Orange Pi will do the same job as the old one before :)
Top
 Profile
PostPosted: Wed Jun 28, 2017 11:31 pm
Offline
eshulze - FlightAware user avatar
I just upgraded the software (apt-get update && apt-get upgrade) I then rebooted and it moved to the new feederid system.
Can you please help re-point to my old one? I don't want to loose my streak if I don't have to over a simple reboot.
Old/Correct site: 33214 New site: 58999
Thanks!
Top
 Profile
PostPosted: Thu Jun 29, 2017 1:17 am
Online
FlightAware Member
Thanks!
If you want to restore your old site, take following steps:
(1) Note down the mac address from your Flightaware stats page of the old site
(2) Delete the new 128 bit feeder id (xxxxxxx-xxxx-xxxx-xxxxxxxxxxxx) from following places
  • pi@piaware:~$ sudo rm /var/cache/piaware/feeder_id
  • pi@piaware:~$ sudo nano /boot/piaware-config.txt
    #scroll down to bottom of file and see if you can find a line "feeder-id xxxxxxx-xxxx-xxxx-xxxxxxxxxxxx # updated by fa_piaware_config". If the line is there, delete this line, and save file. If you dont find this line, close the nano editor.
  • pi@piaware:~$ sudo nano /etc/piaware.conf
    #scroll down and see if you can find a line "feeder-id xxxxxxx-xxxx-xxxx-xxxxxxxxxxxx # updated by fa_piaware_config". If the line is there, delete this line, and save file. If you dont find this line, close the nano editor.
(3) Spoof mac address as follows:
pi@piaware:~$ sudo nano /boot/cmdline.txt
#this file has all text in one line. At the end of this line, add one space and add "smsc95xx.macaddr=xx:xx:xx:xx:xx:xx" (without quotes " "), where xx:xx:xx:xx:xx:xx is the mac address you noted from old site's stat page.
Make sure that there is no line break between existing text and "smsc95xx.macaddr=xx:xx:xx:xx:xx:xx", else the spoof will not work.
(4) Now reboot the pi for spoof to take effect.
Check your Flightaware stats page.
Top
 Profile
PostPosted: Thu Jun 29, 2017 7:55 am
Offline
FlightAware Staff
If you started from a piaware 3.3 sdcard image then upgrading the system packages has left your system in a broken state (see the announcement post in this forum); I suggest reimaging with 3.5.0, which should return you to the correct MAC address & site association.
Top
 Profile
PostPosted: Thu Jun 29, 2017 11:16 am
Offline
It was already on 3.5.0.
Top
 Profile
PostPosted: Thu Jun 29, 2017 11:23 am
Offline
Thanks!
This worked perfectly! Thanks!
Top
 Profile
Who is online
Users browsing this forum: abcd567, Akubra, creatuity, EGBWJon, nameredacted, SoNic67 and 1 guest
Search for:
Jump to:
