w7psk
July 5, 2015, 4:42am
1
I have the temp monitor file going fine per this thread
ads-b-flight-tracking-f21/temperature-limitations-on-the-equipment-t26939-25.html
What I would like to do is take the temperature file created in var/log (var/log/tempcheck.log) and append it to tempcheck.log.yesterday and then have a new one made to dump
the temp information into it.
Similar to the piaware log
thanks
What about doing:
$ sudo pico /etc/logrotate.d/temp-check
In that file paste in:
/var/log/tempcheck.log {
daily
rotate 4
copytruncate
Change the “4” to the number of days you want to keep the logs. It will only hold 4 days (+ the current days log being created).
I think that will do. I’m sure someone will speak up otherwise.
w7psk
July 5, 2015, 6:17am
3
N456TS:
What about doing:
daily
rotate 4
copytruncate
set it for a 2 day rotate … Ill see what it does
w7psk
July 6, 2015, 1:23am
4
Hmm Getting an error and I think its permissions
-bash: /var/log/tempcheck.log: Permission denied
Not sure which CHMOD setting to use.
Give a fish answer: chmod a+x
Teach fishing answer: man chmod
A log file shouldn’t need executable permissions. I would instead check what the owning UID/GID are, and what the overall permissions are.
w7psk
July 6, 2015, 5:38am
7
The file its self is in /Var/Log … I was trying to just append it each day …
Owner is Root
-rw-rw-r-x 1 root root 3550 Jul 5 22:17 tempcheck.log
Where the error is, its when I log in its supposed to give me the temp of the rig (which it is) but just before that it gives me this error
Its all per the above link.
what is the user that is running the temperature logging program.
can you sudo tempcheck > logfile maybe?
w7psk
July 6, 2015, 1:46pm
9
I log in as pi …
-rwxr-xr-x 1 root staff 166 Jul 1 08:10 tempcheck
when I do sudo tempcheck > Testfile
It gives
sudo tempcheck > testfile
-bash: testfile: Permission denied
Apparently pi doesn’t have -bash permissions.
w7psk
July 6, 2015, 1:51pm
10
On the good side. The job is working found these in my /var/log directory today
tempcheck.log
tempcheck.log.1
see if it fills up tempcheck.log
