Post new topic Reply to topic  [ 13 posts ]
Author Message
 Post subject: Asus Tinkerboard
PostPosted: Mon Apr 24, 2017 1:51 am
Offline
EmilK - FlightAware user avatar
Hello there
got this toy yesterday (wife decided to surprise me)
Is there any possibility to use it instead of an Pi3? The Tinker OS seems to be debian based. Anyway, any kind of feed-back will be greatly appreciated.
Infos at
https://www.asus.com/Single-Board-Compu ... _Download/
select "others" to see the entire list.
Emil
Top
 Profile
 Post subject:
PostPosted: Mon Apr 24, 2017 7:31 am
Offline
FlightAware Member
conligwx - FlightAware user avatar
I can't see any reason why not. Just put Debian on it, then use one of the methods over here:
ads-b-flight-tracking-f21/bake-a-pi-t38885.html
And use option 2 or 3 and skip the Jessie image installation.
You will of course need to make sure SSH is enabled. Trial and error I guess.
Top
 Profile
 Post subject: Re: Asus Tinkerboard
PostPosted: Mon Apr 24, 2017 7:35 am
Offline
FlightAware Staff
obj - FlightAware user avatar
It's a Cortex-A17 so I don't see any big deal there. No guarantees that the binary packages will work, but you should certainly be able to build from source without too much trouble.
Top
 Profile
PostPosted: Mon Apr 24, 2017 1:22 pm
Offline
https://flightaware.com/adsb/stats/user ... tats-41764
Top
 Profile
PostPosted: Mon Apr 24, 2017 1:42 pm
Offline
FlightAware Member
EmilK wrote:
https://flightaware.com/adsb/stats/user/EmilK#stats-33248
Great! Congratulations.
Did you succeed in using available binary packages for dump1090-fa & Piaware 3.5,
OR
Did you built these from source?
Top
 Profile
PostPosted: Mon Apr 24, 2017 1:56 pm
Offline
I used the info provided by conligwx, option 2, steps 7 and 8.
Only that at start it set my location wrong but I change it.
No other problems noticed.
The 2 receivers are using the same antena but the old one (PI3 based) is using the Pro stick (orange) and the new one is using the Pro Plus version (blue).
Thanks again
Top
 Profile
PostPosted: Sun May 14, 2017 10:06 am
Offline
Update:
The system does not look really stable, is often off-line and after a restart is not receiving any airplanes, I have to restart it a few time in a row to get it working. I guessed that maybe I have some temperature problem because I received quite a lot of Ajax connection error so I modified an acrylic case to accept an 40x40 mm 5V fan but the error messages are still there but are disappearing a lot faster as without active cooling so I assume that the temp is still playing a role here.
Secondary something I still can't understand (technical description of the 2 systems that are running)
Antenna: 10 db 1090 Mhz antenna (the russian one) with an PGA103+ based LNA stated with about 16 db amp at 1 Ghz power-supplied using an external 12 V power source. Cable about 20 m of RG6.
System 1.
Flightaware Pro stick with Flightaware 1090 Filter
getting up to 1100 messages/second, max range 425 Km in the last week and 483 Km in the last month (using the statistic from adsb project page https://www.adsbreceiver.net/ )
System 2
Flightaware Pro Plus stick with an cavity filter for 1090 Mhz with a pass band 1086 - 1094 MHz, it gets max 600 messages/second and similar range as the system 1. No statistic info about range.
To mention: both system are feed over a splitter from the same antenna+amp combo.
Question why is system 2 receiving less messages as system 1?
Using system 1 with the cavity filter I have lower values (messages and range), system 2 with the Flightaware filter I have overload (messages rate in range 20-100/sec).
Emil
Top
 Profile
PostPosted: Sun May 21, 2017 5:55 am
Offline
Since a few days I got
[2017-05-21 12:52 CEST] failed to write status file: couldn't open "/run/piaware/status.json.new": too many open files
[2017-05-21 12:52 CEST] traceback: couldn't open "/run/piaware/status.json.new": too many open files\n while executing\n"open $newfile "w""\n (procedure "write_status_file" line 6)\n invoked from within\n"write_status_file"
and on website the feeder and Mlat icons are missing....
NOT PRESENT Web Interface: View live data (requires local network connection)
NOT PRESENT PiAware
NOT PRESENT FlightAware
NOTPRESENT MLAT
But on the right side I have
Feeder Check-In: 14 minutes ago
Feeder Type: PiAware 3.5.0
Multilateration (MLAT): Supported / Enabled
Any ideas?
Top
 Profile
PostPosted: Sun May 21, 2017 6:17 am
Offline
UPDATE: A few reboots and the website looks OK now, Mlat client is also active
Top
 Profile
PostPosted: Sun May 21, 2017 6:34 am
Offline
FlightAware Staff
This is a file descriptor leak, but I don't know of any leaks in the current version of piaware. It may be a leak that's not triggered on a standard install or an older leak that has been fixed in the current piaware.
What version of piaware are you running?
What is the base distribution?
Are there other errors showing in piaware.log after a reboot?
Top
 Profile
PostPosted: Sun May 21, 2017 7:09 am
Offline
linaro@linaro-alip:~$ cat /etc/*-release
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
uname -a
Linux linaro-alip 4.4.16-00006-g4431f98-dirty #1 SMP Mon Apr 17 17:27:25 CST 2017 armv7l GNU/Linux
Piaware installed version 3.5.0
No other errors listed after reboot
Top
 Profile
PostPosted: Tue May 23, 2017 1:02 pm
Offline
The error message appeared again....
Top
 Profile
PostPosted: Tue May 23, 2017 1:23 pm
Offline
FlightAware Staff
Try running lsof against the piaware process when it's in that state to see what the leaked descriptors are.
Top
 Profile
Who is online
Users browsing this forum: Akissack, davewill2010, Google [Bot], rjbiii13 and 1 guest
Search for:
Jump to:
