Post new topic Reply to topic  [ 594 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24  Next
Author Message
 Post subject: Re: Announcing PiAware 3! (Latest version: 3.5.0)
PostPosted: Mon Apr 03, 2017 6:45 pm
Offline
FlightAware Member
jcinnb - FlightAware user avatar
Thank you so much. That was really easy!
Top
 Profile
PostPosted: Mon Apr 03, 2017 10:47 pm
Offline
Robidouxs - FlightAware user avatar
Updating to 3.5.0 resulted in my device locking up entirely, nothing would function. Erasing entire SD Card and remounting the PiAware software.
Top
 Profile
PostPosted: Tue Apr 04, 2017 12:03 am
Offline
FlightAware Member
edgy - FlightAware user avatar
http://piaware.flightcdn.com/piaware-sd ... .0.img.zip
This link (on the build page) is dead.
Where's the latest image?
Top
 Profile
PostPosted: Tue Apr 04, 2017 12:25 am
Offline
rsmath - FlightAware user avatar
thanks for the easy update path for 3.5.0.
Some thoughts:
The Flightaware Logo and the Skyview banner are so thick (about 3/4" to 1" thick on my screen) so it chokes away a good portion of the outer aircraft range at the map zoom level I like the most. It would be nice to thin the bar significantly or change its transparency so you can see aircraft behind it.
the click on aircraft to get detailed info box is much bigger than in 3.3.0 so it'd be nice to tighten up that info box to the size it was in 3.3.0 so it doesn't take up a big piece of screen to view. The hover for quick aircraft info is also a big box but with only 3 items it's not too bad for something that's temporary and not a more permanent info box like when you click on aircraft icons.
love the altitude/color bar. Now I see why I never get any yellows, reds, oranges because those elevations are all below the elevation of the local airport which is represented by planes with light green color.
Top
 Profile
PostPosted: Tue Apr 04, 2017 12:30 am
Online
FlightAware Member
edgy wrote:
http://piaware.flightcdn.com/piaware-sd-card-3.5.0.img.zip
Gone With The Wind! :D
Top
 Profile
PostPosted: Tue Apr 04, 2017 12:51 am
Offline
To solve my issue I had to reformat my SD card and mount the most current raspberry pi img. I was able to load 3.5 successfully via the download command line text. 3.5 now functions 100%.
Top
 Profile
PostPosted: Tue Apr 04, 2017 3:54 am
Online
FlightAware Staff
obj - FlightAware user avatar
There is a step that got missed to copy the new image to the CDN, should be fixed in a few hours once Houston is awake.
In the meantime you can get the image here: https://flightaware.com/adsb/piaware/fi ... .0.img.zip
Top
 Profile
PostPosted: Tue Apr 04, 2017 3:55 am
Online
FlightAware Staff
Did you preserve anything from the failed sdcard?
Top
 Profile
PostPosted: Tue Apr 04, 2017 4:08 am
Offline
FlightAware Member
conligwx - FlightAware user avatar
I noticed this morning the Skyview on Chrome using my Android phone was all over the place. I couldn't even close the settings menu so it made it near impossible to view the map. Anyone else tried viewing Skyview on their phone?
Top
 Profile
PostPosted: Tue Apr 04, 2017 4:46 am
Online
FlightAware Member
Too late!
Already downloaded and wrote latest Jessie Lite, and installed Piaware 3.5 + dump1090-fa (package install).
Top
 Profile
PostPosted: Tue Apr 04, 2017 5:05 am
Online
FlightAware Member
I can see it OK on my Android Phone / Chrome
Top
 Profile
PostPosted: Tue Apr 04, 2017 8:29 am
Offline
AustinBanttari - FlightAware user avatar
Same issue using it in Safari on my iOS devices. Using Chrome on my iPhone yielded better results, but between the huge Info popup and the other elements, I can't really see the map.
Also, can't get it to work decently in Chrome in Windows7. Had to resort to IE. *Ugh*
Top
 Profile
PostPosted: Tue Apr 04, 2017 8:43 am
Offline
kd7eir - FlightAware user avatar
Working perfectly in Chrome and Firefox on Windows 10 and Android 7.
Top
 Profile
PostPosted: Tue Apr 04, 2017 8:46 am
Offline
yatesd - FlightAware user avatar
Mine works fine on my iOS 10.3.1 iPhone. One problem I do have with Skyview is the NEXRAD. It shows weather that isn't there. Like it is holding onto some cached image that isn't refreshed. We have clear skies in South Texas today but it is showing storms. I have tried toggling it on and off. No change.
Edit: OK, well, I rebooted my RPi and it is now showing NEXRAD correctly/current.
Top
 Profile
PostPosted: Tue Apr 04, 2017 10:09 am
Offline
FlightAware Member
w7psk - FlightAware user avatar
Did a sudo apt-get update/upgrade and Im still at 3.3.0 ?
Tried the update on My ADS-B and still at 3.3.0 instead of 3.5.0?
Not sure what to do next. Dont want to re-image if I dont have to.
EDIT: Got it working.
Top
 Profile
PostPosted: Tue Apr 04, 2017 10:46 am
Online
FlightAware Member
OrangepiPC (OS Armbian) - Successful upgrade from version 3.1 to version 3.5
FIRST ATTEMPT: FAILED
Code:
pi@orangepipc:~$ sudo apt-get update
pi@orangepipc:~$ sudo apt-get install piaware
[sudo] password for pi:
Reading package lists... Done
Building dependency tree
piaware is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@orangepipc:~$ sudo apt-get install dump1090-fa
dump1090-fa is already the newest version.
SECOND ATTEMPT: SUCCESS
Code:
pi@orangepipc:~$ sudo systemctl stop piaware
pi@orangepipc:~$ sudo systemctl stop dump1090-fa
pi@orangepipc:~$ sudo systemctl stop pfclient
pi@orangepipc:~$ sudo systemctl stop fr24feed
pi@orangepipc:~$ sudo dpkg --remove dump1090-fa
pi@orangepipc:~$ sudo dpkg --purge dump1090-fa
pi@orangepipc:~$ sudo rm -rf /usr/share/dump1090-fa/html
pi@orangepipc:~$ sudo dpkg --remove piaware
pi@orangepipc:~$ sudo dpkg --purge piaware
pi@orangepipc:~$ wget http://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_3.5.0_all.deb
pi@orangepipc:~$ sudo dpkg -i piaware-repository_3.5.0_all.deb
pi@orangepipc:~$ sudo piaware-config allow-auto-updates yes
pi@orangepipc:~$ sudo piaware-config allow-manual-updates yes
pi@orangepipc:~$ sudo reboot
Top
 Profile
PostPosted: Tue Apr 04, 2017 12:10 pm
Offline
FlightAware Member
Ok got home, cleared cache, still no joy...
Top
 Profile
PostPosted: Tue Apr 04, 2017 12:15 pm
Online
FlightAware Staff
That is a symptom of the CSS failing to load correctly, IIRC.
Top
 Profile
PostPosted: Tue Apr 04, 2017 1:09 pm
Offline
FlightAware Staff
ericcarlson - FlightAware user avatar
Hard refresh of the browser cleared this for me (e.g., Shift-Refresh or whatever the equivalent is on your browser) if you run into it.
Top
 Profile
PostPosted: Tue Apr 04, 2017 2:07 pm
Offline
FlightAware Member
ExCalbr - FlightAware user avatar
Feature lost or different UI?
If you click an airplane icon, an info screen pops up. You used to be able to click the top, left corner (registration number, I think) to center the plane on the display. The page would then track the centered plane. That feature seems to be gone now, unless there is another way to trigger it.
Top
 Profile
PostPosted: Tue Apr 04, 2017 3:16 pm
Offline
FlightAware Member
Managed to get it working by clearing the app cache in the end in the Android Settings, Apps, Chrome, Storage, Clear Cache.
Top
 Profile
PostPosted: Tue Apr 04, 2017 3:22 pm
Online
FlightAware Staff
You can doubleclick on the table entry or the aircraft icon itself but we do seem to have lost the ability to do it from the info window, I'll see about getting that fixed.
Top
 Profile
PostPosted: Tue Apr 04, 2017 4:12 pm
Offline
FlightAware Member
Cool. Those options work for me.
Top
 Profile
PostPosted: Wed Apr 05, 2017 4:23 pm
Offline
meznard - FlightAware user avatar
Coming from 3.1.0, you used to be able to set "ChartBundleLayers = true" in the config.js file to get a couple other layers. This setting appears to no longer work. I only have the 5 options under "overlay toggles"
Has this been removed or relocated to a different spot?
Top
 Profile
PostPosted: Thu Apr 06, 2017 6:01 am
Offline
FlightAware Member
I feel I should know this, but I do not.
3.5 is showing B-787s with 4 engine, "747 like icon." Is there an EZ fix, and if so, how? Thank you.
Top
 Profile
Who is online
Users browsing this forum: abcd567, ArkLabs, LeifHenrix, mcklai, TomMuc, WillemPennings and 1 guest
Search for:
Jump to:
