I’d like my android device to supply data but the battery life is limited so I’m finding that the device powers down, normally when I’m away from home.
I want to connect a constant power supply as well as my ADS-B dongle.
Can anyone point me in the right direction for a Samsung Galaxy Tab S dual power supply and micro usb cable please?
Thanks for the suggestions.
The main issue with the hubs is that most don’t actually charge the device at the same time.
I had considered wireless charging while the device was transmitting data but typically the tablet I have doesn’t support this function.
For the price of the cables and hubs i’ll pick a couple up and see what they can do.
Thanks again.
I’d just use the android device is a wifi hotspot (unless you have wifi there) and just feed of a raspberry Pi.
You can use the android device to monitor the Pi (put an SSH client on the tablet and you could modify the setup too)
This will work mobile … the only problem with it is that Flight aware know where your base is and this setup could be used when mobile or on vacation and might dis-believe data if it came from too far away from your regular position.
